Doesnt look too bad, just wish it had some other choices for microstepping.
Dynomotion has introduced a new stepper driver, the KStep ( http://www.cnczone.com/forums/dynomo...s_stepper.html ). I was able to purchase one a few weeks ago (before they were officially released), and have had a chance to test it. It is designed specifically to interface with their KFlop interface, but is perfectly capable of operation from the LPT port with Mach3/EMC2 (it will require converting the DB25 to a 24 pin dual row header, but that is not a particularly difficult task). It has 16 microsteps per step, so using Mach3/EMC2 with the LPT port will require a fairly high frequency pulse train (48,000 steps per second for 900RPM in a 200 step/revolution stepper) if you are using single start ACME lead screws, you should make sure your PC/OS can handle the fast pulse train.
I thought I would mention this driver here in the DIY section because the KStep is a 4 Axis driver that offers up to 5A per axis and has a retail price of only $199 and that makes it very attractive to DIYers looking for a great value in a driver.
I currently have a G540 in my desktop CNC; I plan to put the KStep in my new build (hopefully I will start on that soon, lol. I have rails/trucks, steppers and a driver, so all I need now is time!) I have tested the KStep with both NEMA23's and a NEMA34, and it performs beautifully. I would be happy to answer any user-oriented questions about the KStep, please direct any technical questions to Tom in the Dynomotion forum.
Fish
Hi!
looks like a good stepper driver, just wondering how it will work with Windows.
You mentioned that it is important to "make sure your PC/OS can handle the fast pulse train" is this Lynux hardware?
Also do you know how to make one from scratch open source?
Thanks!
Rob from what is a cnc
