It could be mechanical binding on one side. Make sure that both motors are locked when powered up. Also, it can be settings in Mach3 (or EMC2?)
If Mach3, go to "Ports and Pins" settings tab. Check that the STEP signals are set to "Active High". One motor needs to be reversed from the other so they both go the same direction.
CarveOne
LinkBack URL
About LinkBacks
