Results 1 to 7 of 7
Thread: Is it possible to somehow wire this spindle inverter up to Mach3?
    Sep 2004
    Currently I need to turn on the spindle by pressing the blue button on the inverter then press cycle start, I'd like to use Mach to start the spindle, control the rpm and stop the spindle.....is it possible?
    Attached Thumbnails Attached Thumbnails Is it possible to somehow wire this spindle inverter up to Mach3?-dsc01281.jpg   Is it possible to somehow wire this spindle inverter up to Mach3?-dsc01282.jpg   Is it possible to somehow wire this spindle inverter up to Mach3?-dsc01283.jpg
    Registered DennisCNC's Avatar
    Aug 2005
    Clearwater, FL US
    Easy, find the manual for it. See how to program the I/O lines to do what you want and wala. The I/O lines usually take 0-10 volts and 4-20 mA. Or put up manual i'll look at it. You can make it control the speed also.
    Does it only have the Network plug in it?
    Most vfd's i've seen also have i/o lines
    Dennis
    Sep 2004
    It has the network plug, (pics above) I tried to download a manual for it but I can't find one.
    What is the network plug for?
    Aug 2005
    Clearwater, FL US
    The network plug is for RS-485/232 serial com. Using that it will get compliated. Did you open up the front cover of the vfd to see if there are any other connectors?
    Dennis
    Sep 2004
    No I haven't I will open it up tomorrow. Thanks, I will let you know how I go.
    Sep 2004
    I emailed the company for a manual, but I'm awaiting a response.
    Below is a pic inside the cover.
    How many terminals do you normally need to use?
    Attached Thumbnails Attached Thumbnails Is it possible to somehow wire this spindle inverter up to Mach3?-dsc01293.jpg
    Aug 2005
    Clearwater, FL US
    There you go! Just get the manual and it will tell you exactly how to set the settings so the i/o lines do what you want. With out a manual it will be very hard.
    EDIT:
    You would use one to turn it on anf off and to vary the speed that depends on what the manual says.
    It looks like terminal 6,7,8 are for speed control with a external POT.
    Dennis
  • Posting Permissions
