It looks like Sintra. You should not cut Sintra with a laser as it gives off dangerous gasses and it is corrosive to the parts of a laser. If you say that the hole looks better then you need to change the direction of your cut. If I use a Gerber gold bit P80368A it does a nice job cutting. The one I listed is long because I cut 25 MM Sintra.
LinkBack URL
About LinkBacks
