Results 1 to 5 of 5
Thread: Prepping CRS for paint...
    Mar 2010
    us
    What should I use to prep ColledRolledSteel for paint?
    Can I simply use lacquer thinner or the like to clean of the dirt and grime before paint?
    Thanks.
    Apr 2007
    Quote Originally Posted by adam_m View Post
    Thanks.
    I just wipe it down thoroughly with acetone, lacquer thinner, or Prep-Sol. Usually acetone. Any part of the steel that will remain unpainted will get two or three coats of carnuba wax with buffing between coats with a soft cloth. This retards rust in cold damp weather.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Mar 2010
    us
    Since this CRS will be for the X,Y, and Z axis do you polish the edges after you paint, I assume yes?
    Thanks,
    Adam
    Apr 2007
    Yes, wax and buff after the paint has hardened enough. 1" wide masking tape centered on the 1/4" edges will overlap the sides enough paint free area for the bearing carriages from CNCrouterparts to roll without interference from the paint thickness. The waxed bare metal stops rust and adds no significant thickness so the bearings still roll on essentially bare metal. You can re-wax it as a 6 or 8 month maintenance item if you wish to.
    CarveOne
    CarveOne
    Mar 2010
    us
    Many thanks Carveone...
    Adam,
    1. Problem- Prepping & Painting a steel rail to prevent rust
      By rnbrown in forum DIY CNC Router Table Machines
      Last Post: 05-18-2011, 12:58 PM
    2. Newbie- Question regarding the prepping of a new X3 mill.
      By RiZ in forum General Metal Working Machines
      Last Post: 12-07-2009, 09:54 PM
    3. NKEA22 electric paint sprayer airless paint sprayer coating machine piston pump
      By sprayercn in forum Product and Manufacturer Announcements
      Last Post: 11-02-2009, 12:52 AM
    4. Need Help!- Prepping lathe for sale
      By TOTALLYRC in forum General Metal Working Machines
      Last Post: 08-30-2009, 11:23 AM
    5. Paint????
      By jnsane84 in forum General Metalwork Discussion
      Last Post: 03-27-2009, 04:54 PM
