If you have a spring loaded anti-backlash nut on the ACME screw that would cause that much resistance to turning by hand. If you disconnect the nut from whatever else it is mounted to then there should be very little resistance to turning the screw by hand, assuming that the motor is also not connected.
CarveOne
LinkBack URL
About LinkBacks
If you can turn the leadscrews with less than 50 oz:in of torque then you should be good to go. My machine has tight plastic leadscrew nuts and I use a similar system to set the machine up.
