hey guys, i've got my cnc router up and going and am wonder where and what types of router bits to use to cut 1/16"-1/4" balsa and up to 3/32" aircraft ply. i've heard using 2 flute upcut bits. i want to use the smallest diameter bit so i can create the smallest inside curve cut(hope that makes sense). i don't mind slowing the speed of the machine down down to get a precise cut. also, where are you getting bits from? enco? thanks a lot, toby....
