Results 1 to 9 of 9
Thread: Motor Cable, What are you guys using?
    May 2010
    Im running Probotix ProboStep drivers with their Green Monster motors right now and running them about about 2.8 amps. I am currently running with db9 serial cables but Im seeing the negative effects of using such small cables. What are you guys with bigger machines running for motor cable?
    Joe
    Apr 2010
    Quote Originally Posted by prcdslnc13 View Post
    Joe
    I'm running a Bridgeport with a 7 amp power supply. Still running the original 14 gauge cables installed by Bridgeport, but the gurus tell me that 18 gauge would be more than sufficient.
    But the question is not so much the connector you're using, but what wire size between connectors.
    Tom
    Apr 2007
    Most recommendations I've seen say 20awg is fine. I was using 18awg until I got some high-flex shielded 20awg cables from SkyCraft Aviation. CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    May 2010
    Im running 24awg right now. They were just for testing at the beginning, but It just kept getting pushed aside. I guess Im really asking where to get cable. I cant find the stuff locally anywhere.
    Apr 2007
    Automotive hook-up wire from AutoZone, Carquest, Advance Auto, etc. will work even though it isn't shielded. Just twist four wire colors together in a loose twist of one or two turns per inch so they stay together. I clamp one end of the four wires in a vise and put the other end in a drill. Slowly twist them evenly so that they stay parallel to each other. My big machine had a 19' twisted wire run that had no problems. It is now wired with shielded cable.
    CarveOne
    CarveOne
    Apr 2010
    Not sure what gauge it is, but IIRC, my local trailer supply has a four color ribbon cable made for hooking up trailer lights.
    Tom
    Jul 2010
    18G 4 conductor XLR Mic Cable
    [URL="http://www.cnczone.com/forums/cnc_wood_router_project_log/124543-mountaincrafts_router_plasma_build_thread.html"][U]4' x 8' CNC Wood Router Project[/U][/URL]
    [U][URL="http://www.cnczone.com/forums/woodworking/135576-home_made_drum_sander.html"]Home Made Drum Sander Project[/URL][/U]
    May 2010
    Im running Uni-polar so I need at least 5 conductors. Thats my hangup 4 conductor is pretty east to find.
    Registered Connor9220's Avatar
    Aug 2010
    Stranded wire used to wire up alarms systems. You can get in 4 or 8 conductor 18 gauge on up. HomeDepot has it if your in the US.
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    1. AC power cable in the same cable carrier with motor cables
      By bandtank in forum General Electronics Discussion
      Last Post: 06-01-2010, 07:06 PM
    2. Stepper Motor Cable
      By Starleper1 in forum Benchtop Machines
      Last Post: 05-29-2009, 09:10 PM
    3. Newbie- Motor Cable ????
      By themonster in forum General Electronics Discussion
      Last Post: 07-24-2008, 11:30 AM
    4. Need Help!- Please Guys!!! Spindle Motor O-TC Problem
      By suleman_mani in forum Fanuc
      Last Post: 05-30-2008, 01:17 PM
    5. where do you guys buy your wire and cable?
      By KTP in forum DIY CNC Router Table Machines
      Last Post: 04-30-2008, 11:12 AM
