The range you're trying to use is outside where it probably needs to beI have cut up to 40 IPM and a RPM around 16000. And as slow as 10 IPM and 25,000 RPM. And just about anywhere is between
Try 80 ipm and 12,000 rpm. I think the problem is that you're going too slow, with the rpm's too high.
LinkBack URL
About LinkBacks
