Misumi is one source.
I'm in need of a few shaft couplers to go from 1/4" stepper shaft to 1/2" Acme screw.
I've seen derlin ones, but looking for aluminum or steel.
TIA
I have two of these aluminum couplers on my machine from CNCRouterParts.com:
CNCRouterParts
My "x" axis has a delrin coupler that is working fine for me. I got it from DumpsterCNC.com
Another member just posted this companies info. Pretty informative too. Shaft Collar, Rigid Coupling & Flexible Shaft Coupling Manufacturer
If in doubt try eBay.
Regards - Pat
Lee
I got mine from Enco - Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Check out my projects at www.backyardworkshop.com
Google KTR Couplers. 3 piece spyder type with varying durometer inserts. reasonable too.
Lee Clore
Onyx Industries
Just an FYI.
Aluminum helical type couplers are not always zero backlash nor are they heavy duty. They can break.
Spider type couplings also vary greatly in the amount of backlash you can expect. Some are much better than others with the harder spiders being better.
Oldham type couplings are what I am going with now on everything except where I have SS helicals. I think I went with acetal joints in the Olhams.
I also buy only clamp on style couplings now. If you have ever chased set screws after they loosen up, you too would be a fan of the clamp style.
There are a few places in a cnc build where you can cut a few corners. Couplings are not in those places.![]()
Lee
adding to Lee's comments:
there is no such thing as a zero backlash coupling. I've proven it ZeroMax, KTR, Gerwah, etc. in custom assembly equipment with all sorts of servo sizes. marketing usually defies physics without much concern... There is just very, very low backlash.
KTR offers a split collar hub- highly recommended cause rolling a keyway or a loose set screw to the shaft can be a massive pain.
also, i use KTR's on similar sized shafts to what you reference in your original question on my cnc routers and no problems. good luck!
Lee Clore
Onyx Industries
