That's caused by CV mode. YOU need to increase your acceleration or decrease your feedrate. You can also try playing with the CV settings, most notably "stop CV on angles >"If you make a simple 4" square profile (.030" deep) 3 out of 4 corners are rounded not sharp. The start and finish corner lines don't overlap.
LinkBack URL
About LinkBacks
