Results 1 to 11 of 11
Thread: Need Help from Genius in Building XYZ plate (images Included)
    Mar 2008
    UK
    Hi, I'm building a 3D Rig siilar to this one:
    My is smaller and simpler, I found a problem in the proper Fine XYZ aliment of the two cameras (to make this thing work properly)
    a company have a solution but is too expensive for me:
    I did a drawing of what I have in mind (some sort of aluminum plates with bolts and springs):
    but need some pieces to make it work for example the aluminum plates, springs and this:
    I really appreciate if someone point of a better Design where to buy the pieces or if someone know of a company that sell something similar, Thanks
    BTW: I had done theads in aluminum by hand in the past doing a drill hole and then use a thread tool, is this OK to make them this way?
    Jan 2008
    canada
    I think you are going to have to be more specific. Is this to move a camera along XYZ axes? How much travel is needed?
    Three bolts on a spring plate will work for small motions, but of course the axes are not orthogonal. This is mostly for aligning then locking down the moving plate, as opposed to any scanning or controlled motion.
    Have I understood your application?
    Mar 2008
    UK
    Hi, Thanks for you reply, it only need to travel a few mm around 7mm each bolt, this is only for micro calibration,
    This is where the plate will be:
    This is the camera off and the Camera Plate for easy remove.
    Camera in the Rig
    Project:
    Jan 2008
    canada
    I am sorry, but in my ignorance I still do not know what you are building, so I can't say what will (or won't) work.
    If the goal is to position/orient a small camera, and if there are no forces trying to shake it or change its position/orientation, then a simple set of plates with 1/4"-20 adjustment and lock-down screws would be more than enough. Anything more complicated would require more understanding of what your project is all about.
    Check out 'kinematic mounts' on the web or from optics manufacturers like NewPort, ThorLabs, or Edmund Optics. The ideas are pretty simple and easy to replicate unless you require high accuracy.
    Cheers!
    Mar 2008
    UK
    Thanks, where I can buy the plates and the 1/4"-20 adjustment screws?
    May 2007
    Similar design:
    DIY 3D RIG
    Looks like they're using a cheeseplate for the Y and a macro focus rail for the XZ. Cheap rail: Macro camera focusing rail with 4-way adjustment | eBay
    Jan 2005
    Andy,
    Thanks for reposting a picture of my Z limit switch bracket in your first post. I used my mill but you could use a drill press to drill the hole. I used a hand tap to tap the hole. When I am tapping a hole when using my mill I use a tap handle that you attach to the spindle to ensure alignment but tap by hand.
    Dave
    Dec 2009
    camera plate latch
    hey guys,
    nice looking project.
    i've been looking for similar designs (not pre-made), similar to what you're talking about.
    any ideas about how to design the part i circled in blue from scratch? I've made some dovetailed camera plates, but looking on how to make the latch design for tightening them to the plate, something more elegant that just having a fastener bolt put pressure on the dovetail.
    thx
    matt
    Attached Thumbnails Attached Thumbnails Need Help from Genius in Building XYZ plate (images Included)-ima2.jpg
    Registered Pplug's Avatar
    Jan 2007
    Draw a circle and offset the center hole by a small amount ie.. For a 1.5" diameter cycle offset the hole by about .125" that will give you the offset cam action your looking for.
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
    Dec 2009
    Quote Originally Posted by Pplug View Post
    Thanks! there's also some sort of spring mechanism.. does anyone know how that works?
    matt
    Nov 2007
    To the original poster,
    I think if you do a search on ebay for "xyz stage" you will find some different examples of the kind of thing you are after, there is a wide variety in size,accuracy and cost.
    you should be able to find something that suits your needs, otherwise if you really need to build something yourself you can also buy just the screw mechanism from micrometer drives which you could use to give you accurate and fine control, more accurate than just bolts.
    rgds,
    Andrew
    1. Hanwah ML12 & Iemca Genius 112???
      By MX1 in forum CNC Swiss Screw Machines
      Last Post: 12-23-2011, 04:08 PM
    2. Any tips for designing a fixture plate / tooling plate?
      By thackman in forum Benchtop Machines
      Last Post: 12-19-2008, 12:26 PM
    3. Diy kit with everything included
      By Acidshock in forum DIY CNC Router Table Machines
      Last Post: 12-18-2007, 10:58 AM
    4. Minimax C26 Genius
      By LJB in forum WoodWorking
      Last Post: 09-18-2007, 06:17 AM
    5. Aluminum: flat, bar, sheet, plate, tooling plate??????????
      By Dan S in forum DIY CNC Router Table Machines
      Last Post: 06-28-2007, 01:48 AM
