Results 1 to 4 of 4
Thread: Brilliant Design 72"x36"x9" CNC Router (HobbyCNC based)
    Registered vondeliusc's Avatar
    Dec 2007
    Wink Brilliant Design 72"x36"x9" CNC Router (HobbyCNC based)
    Hi- My name is Christian.
    I am announcing my >>>DIY CNC Router<<<
    The link is my detailed blog regarding this build
    Build: HobbyCNC-electronics based router.
    Material: MDF 0.75"
    Parts- cut out with table saw and post processed.
    Design Basis: WoodworkerB's Blog
    Actual size: 80" x 60" x 42"
    Working size: 72" x 36" x 9"
    CNC Design Tool: SolidWorks
    Motors: 200oz-in 1.8 degree (200spr)
    Lead Screws: 2-start 5tpi
    Resolution: 0.001"
    Machine Control: Mach3
    Part design: SolidWorks exported as DXF
    Plans will be available (someday, if there is interest)
    Completion target date: 07/2011 (?)
    I am a design engineer, I work in SolidWorks, I own and operate a PlasmaCAM CNC plasma torch (w Miller 375 Xtreme inverter 27a). I built the HobbyCNC chopper stepper driver kit, and have tested the motors with Mach3 and appears to operate nominally.
    Feel free to get ideas for your own, or copy what I have done.
    Visit my ongoing construction blog for this project and leave comments or whatever here.
    Enjoy-
    -Thanks
    -Christian
    Jan 2008
    canada
    Hi Christian;
    That is quite a large machine! Are the sides of the gantry going to be MDF or metal? Either way, I would think that you are going to have some sway because of the height. Plus, the gantry sides become very narrow just below the Y stepper motor. Unless there is a very good reason for this, this looks like a weak point in the structure.
    Good luck!
    Dec 2007
    Paul-
    WoodworkerB's design did not allow the carriage to move past the gantry sides. So, as I designed, one of my criteria was to allow the gantry track to let the router bit center go to within ~1" of the sides of the table, to be able to reap the full width of the table. I know that this is a weak point, so I will use the CNC plasma cutter to create metal plates that will be mounted on the outsides with several bolts above and below to attach thru the gantry faces-kind of an exaggerated 'C' affair probably of 0.125"(?) Aluminum. And I wanted to have a fairly large table to be able to fabricate skins for the CriCri aircraft I am building.
    There is also a 2nd y-axis stabilizing cross-member behind the gantry track that is not visible, which should reduce(?) Y wobble.
    Thanks for the comment.
    -Christian
    Dec 2007
    Quote Originally Posted by PaulRowntree View Post
    Hi Christian;
    Good luck!
    BTW-MDF. And the size was driven by McMaster-Carr, because the ACME threaded rods come in 36 or 72" lengths; so, two 72"ers with one full for X and #2 cut in two for Y and Z. And dumpsterCNC anti backlash and couplers.
    -Christian
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 01:15 AM
  2. new "small size" benchtop cnc mill based on weiss wmd16v
    By ihavenofish in forum Benchtop Machines
    Last Post: 07-31-2011, 11:01 PM
  3. Newbie- Igus W chain driven router design 32"x82"
    By chrismp in forum DIY CNC Router Table Machines
    Last Post: 09-26-2010, 12:38 AM
  4. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-08-2009, 12:36 PM
  5. Need Help!- "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 03:33 AM
