Put T nut's into another sheet of MDF and screw that to your torsion box. That's what I did.
Another First Router
Hi, CNCZone.
Sorry for the confused nature of this post. I have several issues that need work and I'd really appreciate it if you could lend me the benefit of your experience.
I've got a work surface that's 8'x52"'x3/4" MDF. The surface is the top of a torsion box. The outer 2" on each side are occupied by the rails & chain drive. The torsion box sits atop a wooden frame. Because of the chains & box I can't clamp work around the outside edge and I can't put t-nuts from underneath.
Wood I get from my supplier isn't always dead flat. I'm pretty sure my table is sagging, too - the legs aren't directly under the torsion box because I thought if I made them wider that would give me storage space for large sheets under the machine.
Please help me figure out:
a) how to hold work pieces steady
b) how to stop the sag & properly level the surface
I have a 1/2" bit I can use as a fly cutter to level the surface, once I'm sure it isn't going to move again. I'd like to change the frame to hold the machine better but I'd need a lot of help to move the torsion box (it weighs a hell of a lot)
I've tried putting threaded insert into the table top but they pull out over time, leaving me with a mess to putty shut. I tried weights to hold pieces down. That worked pretty well but fails hard when it gets in the way of the gantry.
Suggestions? My budget is next to nothing, I invested a lot to get this thing and didn't plan for all the delays.
Thank you!
Nice! I'm confused by one thing: why drill 1.2" into a 1/2" sheet?
There's a 3/4" sheet below the 1/2" sheet, and this allows the bolts to go below the t-nuts. This lets me use the same length bolts for different thickness materials, as I have an extra 3/4" to play with.
Oh so you planned it such that when you flipped the board over (with the t-nuts underneath) the holes would all line up? Nice.
I have no room on the edges to put y=0 fences unless I sacrifice some of the envelope. If it were you, would you give up some of the envelope to add a fence? How would you go about it?
I see the fence you use has horizontal slots. Is this for alignment adjustment, or did it serve some other purpose?
Thank you so much for all the help! I just read the entire thread for your CNC build. I'm so dumb I don't even know how to make money off my machine yet, I just knew I had to get one. :T
Another option is a T-slot or T-track table. I have tried both.
For a T-slot table simply purchase a T-slot router bit and route T-slots in a spoilboard, typically a high density plastic, that is screwed to your table.
Fot a T-track table, purchase T-tracks, such as;
Buy INCRA T-Track, 48" length at Woodcraft.com
Screw the T-tracks to the table and fill the spaces inbetween with plastic, wood or MDF that is thicker than the T-tracks are tall.
It seems to me the slots would get really annoying when they catch on material being slid on/off the table and adding new t bolts would mean going back and forth a lot.
Having tried both, which do you prefer to use?
I use the machine to route the edge of the fence straight. Every now and then, I loosen the bolts, slide it over a little, and reroute it, to make sure it's exactly zero.I see the fence you use has horizontal slots. Is this for alignment adjustment, or did it serve some other purpose?
I can't tell you how you should use your machine. Can you give up any usable space? I don't know. But, you can always remove it if you need more room.
Maybe you could use T-nuts secured from the bottom of you spoil board. Seems like they would hold better than wood inserts. I personally don't use them, but it is another alternative.
If you use Ger21's method of putting in t-nuts from underneath you have to make sure that you control the depth of the c'bore. Otherwise, over time the t-nut can back out and then you have a problem. I used this method for a while, I was not fond of it since the holes tended to fill up with dust and chips.
Another method that works and a lot of people use is t-tracks. You screw them to the top and then fill the space the space between them with either mdf or plywood. I am not a fan of routing slots to put them in. The reason is that if you use 3/4 material to fill in between them, this material acts as your spoil board and it is easy to replace just the sections that need replacing.
ger21, did you level the table before you screwed down the board for the t-nuts?
I'm going to have to do something soon myself.
2 things I am considering:
1) 1/4 inch holes, and using cam clamps.
2) keyhole like slots (two big holes, connected by a smaller channel). head of a bolt goes in the hole, and slides under the channel - wing nut on top.
either way, I have to plan to avoid the torsion box underneath.
reading the thread got me thinking, maybe a 1 inch piece of HDPE with T-slot routed would be slick.
-frige
