Results 1 to 6 of 6
Thread: San Jose, CA hardware issue
    Jun 2010
    I need some help trying to debug a hardware issue. It would be great if someone could come over and help me.
    Here is what is going on:
    computer > interface box > control box > cnc (steppers/sensors/etc)
    The machine chirps about every second. It seems the power supply is resetting itself or something. When I unplug the cable to the computer, this noise goes away.
    When the lights in the interface box come on (pin lights) (PMDX card), the CNC will move for a brief moment (x,y,z) as those signals seem to go live. It's a very disconcerting noise too.
    With the computer unplugged, when I wave a wrench in front of the sensors, the lights flash in the control box card and I'm pretty certain in the interface box as well.
    Anyway, all is not well here. I need help. I'm losing money by the second.
    http://www.sweetwoodguitars.com - raising the bar for the electric guitar.
    Jun 2010
    couple more things:
    I'm running Mach3 and it's a woodcam cnc.
    if you know someone in the SJ area, please refer them to me or VV.
    -Glenn
    Jun 2010
    ok, just measured some voltages inside the control box. i'm getting 19v on some spots that should have 5v. ah man. i could have sworn they were correct the other day.
    Apr 2007
    You could have an open ground path in your wiring. Put the black voltmeter probe on the PSU ground terminal and verify +5vdc at the PSU 5v output terminal. Keep the black probe on the same PSU terminal while following the +5vdc wiring and checking each connection for +5v. When it changes to 19v look for a good ground connection at that device.
    You can also turn the system off and check for continuity from the PSU ground terminal to each device's ground connection. If you get a higher ohms reading or an open circuit there is a grounding problem.
    With a device that uses both 5v and another higher voltage you could be seeing a voltage drop through some of the device's internal circuitry if the 5v ground is not connected at the device.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jun 2010
    thanks CarveOne. My power supply is 24v. It drops somewhere later on. Your suggestion is good though. I'll trace the voltage out. I just have to figure out where the voltage drops...or is supposed to.
    Apr 2007
    That confirms my suspicion. 24vdc minus 5vdc = 19vdc.
    CarveOne
    CarveOne
    1. Help with Acu Rite Classic Mill Power Hardware/software Issue
      By Winton1 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 08-03-2010, 08:03 PM
    2. where to buy metal near san jose
      By skipper in forum General Metalwork Discussion
      Last Post: 01-30-2009, 01:31 AM
    3. Need A Quote- MDF routing in San Jose
      By spencermillerrn in forum Employment Opportunity
      Last Post: 08-17-2008, 12:26 AM
    4. Seeking PT in San Jose
      By rnickl in forum Employment Opportunity
      Last Post: 02-26-2007, 11:36 PM
    5. Where to buy tooling in San Jose, CA?
      By Zumba in forum General Metalwork Discussion
      Last Post: 08-04-2006, 08:07 PM
