I decided not to build a moving table design, but go for a moving gantry design instead, I also went for the maximum dimensions I could achieve with the quantity of Bosch/Rexroth extrusion I had ordered (something like 56 linear feet).
Once the corner parts arrived from Bosch I laid out the table frame (first picture) and then adjusted and repositioned things. I wanted this construction to be extra sturdy so I bolted through the extrusions as well as implementing the 90 degree angle braces from Bosch.
Tapping the 45mm x 90mm extrusions with the M12x1.75 tap was quite a bit of work to do by hand, it also taps oddly as the 'vanes' in the extrusion cause the tap to repeatedly slip/grab which is more abusive on the arms and hands.
LinkBack URL
About LinkBacks
