Results 1 to 5 of 5
Thread: Router using ER collets?
    Apr 2007
    England
    Can anyone provide some feedback on the use of one of the many standard collet adapters for routers. I've got a porter cable speedmatic with 1/4" and 1/2" collets but online lots of tooling just doesn't fit. So I was thinking of using something like an ER20 or ER25 adapter.
    Perhaps for ER20:
    Buy Axminster Router Collet Extension (1/2' Shank) from Axminster, fast delivery for the UK
    and ebay E25?
    C1/2-100 ER25 Straight Shank CNC Milling Holder -US | eBay UK
    Any advice?
    I notice some of the ER collets on the web quote runout larger than the adapters. Are there any pitfalls I should watch out for?
    dc
    Mar 2003
    Shelby Twp, MI....USA
    An adapter amplifies any runout in the standard collets, due to the extra length. If you need 1/8" collets, you can get them from Precision solid carbide tools for woodworking and metal forming.
    Porter Cable makes a 3/8", and you can also find 6, 8, 10, and 12mm collets.
    Leigh Dovetail Jigs
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    I've put an er16 holder with a 1/2"(chopped short) shank on my router and it runs great and runs true with it , but i think that anything bigger could be a problem as Ger had mentioned .
    most of those holders aren't balanced and aren't meant to run at such high rpm's and will destroy the bearings in your router
    an er 16 will give you a good range and you'll easily be able to run from 1/8 to 3/8 shank , as long as the one you get is decently balanced which could be a craps shot if your buying chinese . So before you buy it may be a good thing to contact the seller and ask what the max rpm rating is for the holder
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    Apr 2009
    Like Ger said, I'd check out the PreciseBits site first. You can get the ER nut and collets for your router, and they work well!
    Apr 2009
    Amana also sells bushings for different size shanks to fit 1/4" and 1/2" bits; check out toolstoday.com...
    1. Router Bits and Collets from China?
      By rocket67 in forum Commercial CNC Wood Routers
      Last Post: 01-06-2013, 02:55 PM
    2. Need Help!- Help with collets for Craftsman Palm Router
      By louieatienza in forum DIY CNC Router Table Machines
      Last Post: 05-25-2010, 12:09 AM
    3. Hitachi Router M12VC Collets
      By RJSheets in forum Open Source CNC Machine Designs
      Last Post: 04-26-2009, 10:15 PM
    4. Router Collets - FOUND
      By ZigMan in forum Joes CNC Model 2006
      Last Post: 09-07-2008, 04:44 PM
    5. Need Help!- Collets for DeWalt Trim Router
      By jeffmorris in forum DIY CNC Router Table Machines
      Last Post: 05-22-2008, 01:55 PM
