My 2 cents:
1: Keling sells the G540 for $245
Stepper Motor, Stepper Motor Driver,CNC Router, Stepper Motor Power Supply, Stepper Motor Kit, DC Servo Motor, Stepper Motor, Stepper Motor Driver, CNC Router, Stepper Motor Power Supply, Stepper Motor Kit, DC Servo Motor, Keling Technology Inc, USA
2: Since steppers draw power differently than, for example a resistance heater, you don't NEED a PSU of greater than 7A with the G540. Amperage capacity of over 7A is wasted because any more than 7A actual load would blow the G540 internal fuse. So a PSU like the $50 Keling 48V 7.3A is more than adequate to power four 3.5A motors.
3: You don't really need connectors, since they come free with the G540. However, you DO need 4 conductor 22 gauge motor cable wire, current set resistors, (About 5 for $3 shipped from Digikey) and an Estop switch. (Keling, $10) So $45 is reasonable for miscellaneous supplies.
For the above reasons, I would put the G540 total cost estimate at approximately $490.
Also, don't forget that the G540 is optoisolated, fully assembled/tested/guaranteed ready-to-go and you are getting a future fourth axis controller included free, so there is that extra value to be considered. If your application can use it, there is also the added value of the G540 built-in motor speed control circuit.
CR.
