You'll need a perfect seal, or the part will never get sucked down. If you're cutting MDF, the vacuum will suck through the MDF. How fast it goes through, I'm not sure. I should probably make a small fixture and hhok up My venturi and see how it holds MDF.
Not volume, but surface area inside the gasket seal. Vacuum holding force is measured per square inch. The more square inches, the better. With no leaks, and holding a non porous material, you can probably get about 10 lbs/in^2. So a 10"x10" table can get you up to 1000 lbs of force, provided there are no leaks.The size of the vacuum chamber in the table, does size (volume) matter ? I'd like to cut the chamber(s) in a 1" thick sheet of material.
LinkBack URL
About LinkBacks
btw I took a look at your machine and it's in a whole different class. Industrial grade.
