Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: picking to right Interface Board
    Apr 2011
    Exclamation picking to right Interface Board
    Registered doorknob's Avatar
    Jan 2010
    What type of CNC machine are you building?
    Those motors look to be on the small side compared to motors that I have seen other builders use (the holding torque is rated at only 75 oz. in.), but might be OK for a very small machine.
    The interface card to which you have linked appears to be a parallel port breakout board. It is not designed to drive stepper motors directly, rather you would need to connect a motor driver board (either one driver board per motor, or else find a driver board that is capable of handling more than one motor) between that interface board and your motor(s).
    Since those motors are 4-wire units, make sure that you locate a driver board that is designed to drive "bipolar" stepper motors (do not get one that is designed to drive "unipolar" motors).
    The four terminals per axis on the interface board to which you have linked are not designed for direct connection to the four wires of each of your stepper motor(s). Rather, for each axis there appears to be an "enable" pin (to tell the motor driver whether or not to apply power to that axis), a "direction" pin (clockwise or counterclockwise), a "step" pin (to advance the motor by one increment for every pulse on that pin), and a "common" or ground pin.
    In addition it looks like the board has other inputs or outputs such as for handling relay control and limit switches.
    Apr 2011
    thank you i think I understand I will do some reading up on drivers, And yes this is my first cnc and I started off small I was think something like a 10" by 10"
    Apr 2011
    so would this be something that would work?
    4 Axis CNC TB6560 Stepper Motor Driver Controller Board | eBay
    Quote Originally Posted by doorknob View Post
    Jan 2010
    That board has the advantage of combining the functions of the breakout board and a multi-axis motor driver board.
    It is designed to work with bipolar stepper motors, so that part is good.
    A couple of "buts", though.
    First, that specific board is rated for use with motors that draw between 1.5 amperes and 3.5 amperes of current per winding. However your stepper motors are rated at 1.0 amperes per winding, which is out of range. You may be able to find a similar board that is rated for 1.0 amp motors (or, if you are handy with a soldering iron and have experience reworking printed circuit boards, you could buy that board and replace the precision resistors that set the supported current range).
    Second, that board has a maximum motor voltage rating of 36 volts (although people who have used similar boards have recommended selecting a lower voltage power supply, perhaps limited to 30 volts or even 24 volts, in order to have some "breathing room" from the maximum rating to avoid burning out the driver chips). The specific motor that you chose has a relatively high winding inductance, and so it will prefer a higher drive voltage than you can safely support with that board. The higher the voltage, the faster you will be able to run the motor. Depending on your requirements, though, for a small machine like you are planning, the speed at that lower voltage may be OK.
    Finally, some people have had problems with similar Chinese TB6560 driver boards, while others have found them to work OK in their applications. See the following thread for some discussion, including circuit changes that some folks have tried to remedy the problems that they have had:
    http://www.cnczone.com/forums/genera...y_chinese.html
    Apr 2011
    Free Bump, hoping for an answer about that last stepper controller board posted! I have bought two and waiting on arrival, looks like they need motor drivers built for it and this is just a controller board, but would be great to have someone confirm that its useable for a cnc build? Been lurking and reading for ages now, this forum is fantastic!
    Apr 2011
    whoops
    whoops! just noticed newest posts are up the top on my compter at least, so this has already been answered lol phew! But everyone point and laugh at the newb, myself
    Dec 2010
    That board works OK. I've been running one for weeks with no probs & it runs my 5' x 5' table OK. It doesn't need fixing as per that other thread.
    Make sure to tell them you want the lower current board if you do go ahead and buy it.
    Just remember, you get what you pay for - don't expect the performance of a Gecko....
    Apr 2011
    Stepper Motor Driver 5 Axis Interface Board adapter CNC - eBay (item 280629123412 end time May-13-11 08:39:06 PDT)
    Is there any 'common' name for these 5 axis controller boards? thats what iv got two of arriving sometime soon i hope. Has anybody been using them, do they work ok?
    I have assumed i need to build stepper drivers for it but seeing as i hope to eventually build a couple of machines i figured that i can make the drivers suit the motors and keep the same controller. Or have i got it all completely horribly wrong? Thanks in advance cnc gurus!
    Jan 2010
    Quote Originally Posted by essjay View Post
    They are commonly called "parallel port breakout boards".
    That one is the same board that was linked to by the OP. I do not have any experience working with that specific board.
    It probably has similar function to boards such as the "C10 bidirectional breakout board" from CNC4PC at CNC4PC, however there is not much in the way of documentation offered by the eBay seller, so that's just a guess.
    Yes, it sounds like your plan to build motor drivers is a sound one.
    Apr 2011
    phew thanks very much!
    Apr 2011
    heres what i'm using.
    newcncguy - here's the kit I am using and machining aluminum with on a 16"x16" cnc router...
    4 Axis Nema 23 Stepper Motor 287oz-in & Driver CNC Kit | eBay
    Precision is good, torque is good, it came with all docs to wire up and set current and microstepping. It also came with docs to config Mach3 and also came with Mach 3. I'm happy with the quality and ease of installation. On a personal note I would use something stronger then 75oz. in. steppers even in a 10x10 machine. If it is cost you are worried about then this is a bad choice of hobby
    At minimum I would recommend something around 175 oz. in. because you will always want to do more once things start working. I have seen 175 oz in. kits from a seller in california for about $130 with shipping.
  • Page 1 of 2 12 LastLast
    1. Problem- Bridgeport Interact 1 MK2 interface board MK1-1
      By Zoebie in forum Bridgeport and Hardinge Mills
      Last Post: 08-13-2009, 04:33 AM
    2. Breakout board interface
      By sunward in forum Gecko Drives
      Last Post: 05-14-2008, 12:26 AM
    3. Newbie- Serial Interface Board
      By fastnovacrash in forum Controller Cards
      Last Post: 02-12-2008, 05:34 PM
    4. Value for R21 to R28 Output Interface board
      By gaga2410 in forum PicStep Controllers
      Last Post: 10-19-2007, 09:26 AM
    5. Running a parrallel interface board
      By Don C in forum DeskCNC Controller Board
      Last Post: 12-31-2004, 05:45 PM
