Results 1 to 3 of 3
Thread: My Deskstop CNC Router is WORKING!
    Sep 2009
    Hey All,
    I recently got my CNC machine fully working! There's a lot left to improve upon, but I figured I would post a video of it in action. It uses a stationary gantry with a movable base, and the working area is about 1' x 1' x 4".
    [nomedia="http://www.youtube.com/watch?v=wFLmq2fVUz4"]YouTube - Marc's CNC Hobby Router[/nomedia]
    I used a Bosch Colt palm-router as the spindle, and for the control circuitry I used the hobbyCNC kit. Aside from those two components I made it from scratch, using mostly MDF. For the linear movement I used the idea from the buildyourcnc tutorial, which involves aluminum angles and skate-board bearings. Instead of buying expensive bearing blocks, I just took blocks of UHMW-Polyethylene and drilled holes into them that matched the ACME lead size. I bought some anti-backlash ACME nuts from dumpsterCNC, which worked out pretty well (they are mounted to the carriage assemblies using blocks of UHME-PE). I used 205 oz-in (unipolar rating) steppers, but they support a bipolar driver so a future project of mine is to design and build a bipolar driver.
    In the video I am just engraving some wood, but I have also used the machine to mill out a better router-mount, which you can see in the video. I also plan to mill better gantry supports (the current ones are waaaay oversized).
    Post any comments to the youtube video, since I don't check this site as often. Any advice would be greatly appreciated!!!
    Feb 2008
    Great Job!
    -Scott
    Apr 2003
    Looking good!
  1. Bits suggestion for jewelry wax working whit CNC Router
    By liat in forum General Material Machining Solutions
    Last Post: 01-07-2011, 12:36 PM
  2. Problem- Red dot not working
    By Dubliner in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-19-2010, 05:48 AM
  3. Build Thread- CNC Router - Foam/Wood Working
    By thomasnc41 in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 06:17 PM
  4. I am looking to buy a router. Working or not.
    By runinbymdnt in forum DIY CNC Router Table Machines
    Last Post: 12-30-2006, 09:46 AM
  5. my router is working! drawings available for low cost on my site!
    By hpghost in forum Product and Manufacturer Announcements
    Last Post: 10-26-2005, 01:28 PM
