Results 1 to 6 of 6
Thread: What happens when stepper motor is close to a magnet?
    Jun 2010
    I'm curious what would happen if a stepper motor is close to a small electromagnet such as those used to lock a door?
    Feb 2006
    The motor IS A MAGNET !
    Probably keep locking & unlocking the door.
    Don
    IH v-3 early model owner
    Jun 2010
    Thanks. I wondered if it had any magnetic shielding.
    Aug 2005
    It would have to be a fairly strong magnet, and very close.. A while back I stuck a magnetic indicator base to a stepper motor (was the only steel on the apparatus, and was trying to measure movement), the motor wouldn't turn at all. Completely changed the magnetic field of the motor. Depending on the stepper motor, the housing that you see is a functional part of the electromagnetic operation of the motor. (the kind where you can see the stacked steel plates) I'm sure there are some that are shielded as well, maybe the round "can" type..
    May 2010
    Most likely nothing. Things have to be pretty close and or large to be effected significantly by magnetic fields. At least as far as forces are concerned.
    Most likely if anything the stepper would induce a small current to the electromagnets coils causing small magnetic fields on the door mechanism.
    Oct 2005
    I played with a hall sensor around the outside of a square style stepper motor, running and powered down, and there was very little in the way of radiated magnetic field. The magnetism is kept inside the motor pretty efficiently.
    Also magnetic field drops enormously once there is more than a couple of inches air gap between the magnets, so in the case of your motor and door lock I think there's almost zero chance of them affecting each other!
    1. permanent magnet planar motor
      By 971155804 in forum Linear and Rotary Motion
      Last Post: 12-16-2008, 03:15 PM
    2. Can use Permanent Magnet Synchronous Motor ?
      By tivoidethuong in forum Phase Converters and VFD
      Last Post: 07-05-2007, 10:10 PM
    3. permanent magnet motor control
      By grizzly in forum General Electronics Discussion
      Last Post: 01-20-2007, 12:37 AM
    4. Gluing a magnet on PM motor?
      By DennisCNC in forum General Electronics Discussion
      Last Post: 06-07-2006, 09:09 PM
    5. Gecko - close to computer or close to motor?
      By andy_ck87028 in forum Gecko Drives
      Last Post: 11-27-2005, 11:39 PM
