Results 1 to 7 of 7
Thread: MDF releases urea-formaldehyde
    Mar 2007
    england
    I was told that MDF is dangerous and when being worked you should take precations.
    Even after being worked MDF all ways releases urea-formaldehyde etc over time they say to paint it all to lock it in.
    I have used it to make radiator covers and want to know if its really safe as I have NOT painted the back sides of the board that are exposed to that central heating radiator.
    What should I do I have kids and dont want them to be exposed to any thing that could casue problems down the line.
    Jul 2007
    UK
    I think treat it cautiously if you use it continuously, It doesn't show itself like charcoal (you know black soot crap in your nose after doing a barbeque). I think if you use adequate vacuum very close to your cutting point you will be better protected, but MDF dust gets everywhere. Try to avoid it, I reckon it takes 15-20 minutes to settle on the floor after working it.
    Regards.
    Mar 2007
    england
    Hi thanks for the reply.
    I am more worried about what MDF I have in me front room as I have kids and don't want them to be exposed to any thing that could cause a problem in the future.
    Registered jsheerin's Avatar
    Aug 2008
    I can usually smell MDF outgassing when I first come into a room. I'd definitely seal it. I'd be more worried about breathing the dust from cutting it personally - I always wear a canister mask and am working on totally enclosing my router. The fine sawdust is really bad for you. Check out Bill Penz's site for more info.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Jul 2005
    Here read the Wiki on it particularly the Safety aspects of MDF which I copied this from: "Whether these chronic emissions of formaldehyde reach harmful levels in real-world environments is not yet fully determined."
    Medium-density fibreboard - Wikipedia, the free encyclopedia
    Personally I don't think there is any hazard from MDF in a normal home environment. Actually if you had an open fireplace or even and open gas fire you probably get more from these than from any MDF.
    In a manufacturing environment the fumes and dust from MDF can be hazardous with prolonged exposure but that is very different from a home environment.
    Jul 2007
    UK
    I dont think I would be too worried about MDF around a radiator, I would imagine it would be sealed by something anyway from an aesthetic point of view.
    Mar 2007
    england
    Hi all thanks for the replys.
    I may take the covers apart and just put a coat of paint on the whole cover to seal it all.
    I use this
    Toolstation > Power Tools > SIP Tools > SIP Dust Extractor
    And tbh it don't seem to work great but I will need to make a dust shoe then test it.
    1. Just IN- PBC Linear Releases New Product Application Booklet
      By Pacific Bearing in forum Product and Manufacturer Announcements
      Last Post: 04-26-2010, 05:04 PM
    2. Just IN- Jet Edge Releases New Waterjet Table
      By Jetedge in forum Product and Manufacturer Announcements
      Last Post: 03-19-2009, 04:55 PM
    3. TORMACH RELEASES SPINDLE UPGRADE
      By Tormach in forum Product and Manufacturer Announcements
      Last Post: 08-31-2008, 11:45 AM
    4. IMService releases ncPOD controller
      By imserv in forum Product and Manufacturer Announcements
      Last Post: 05-18-2007, 11:54 AM
    5. BobCAD-CAM Releases NEW Version 20 Software
      By CNCdude in forum Product and Manufacturer Announcements
      Last Post: 01-17-2005, 03:15 PM
