Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: Why are my motors so hot?
    Jun 2010
    I'm running 42v through my system. I have a EZg540 set at 5K, yet my motor gets smoking hot, and one burned out. Am I putting too much voltage through them?
    Sep 2006
    romania
    Quote Originally Posted by HereinCS View Post
    voltage will never create heat, current will!
    So I think that you have set the current too high for that motors.
    (It may be a resonance problem too, but I doubt)
    Registered CNC Lurker's Avatar
    May 2009
    What resistor is your stepper supposed to use? I'm using the CNCRourterparts kit, so the EZg540 is supposed to be set to 3.5.
    http://paul-flores.com/
    Jun 2010
    I can't read the value on my EZg540....but I have it turned all the way counter clock wise and the measurement across pins 1 and 5 is 5kOhms.
    Jun 2010
    My motor states 2A and measured 5ohms across each winding
    Sep 2007
    You need a 2k resistor across 1 and 5. That sets your current. The trimpots are only for adjusting low speed smoothness.
    Jun 2010
    I have more than 2k, I have 5K of resistance. The pot is to adjust the EZg540, not the trim pot on the gecko.
    Sep 2007
    Ah, ok I see. Well at 5k it's limited by the drivers at 3.5A/phase (without idle reduction) which is why it's killing your motors. Across 1-5 you should be coming up with 2k when it's adjusted properly. There's a chance you might have a bad pot on the EZ, try turning it while hooked up to a meter to see if it changes.
    Jun 2010
    I had it at 2k but the motor ran hot and fried. Then I noticed my other motor getting hot as well. So I turned up the pot to 5k and it still heated up.
    The motor that fried did so during my calibration. It was making a ton of small steps, then died and triggered an estop function
    Sep 2007
    A warm motor is normal, but obviously we're talking about much more than that if it fried one of them. How long was it running before that happened?
    -the adjustment (counterintuitive) goes the other way. Lower resistance means lower current output. Something is still wrong, but you should be able to set them at 1.5k or so without the motors getting warm for quite some time.
    Jun 2010
    Thanks, maybe I had it back wards. I'll turn them all down to 1.5k.
    But the motor was running for about 20 minutes. Taking very small steps.
    Tinkerer
    Nov 2009
    It is not a random number to adjust to. Why are you now selecting 1.5?
  • Page 1 of 2 12 LastLast
    1. Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China
      By Ling in forum Product and Manufacturer Announcements
      Last Post: 07-12-2009, 05:10 AM
    2. DC motors as servo motors
      By Doug Schwochert in forum Servo Motors and Drives
      Last Post: 12-26-2007, 01:03 PM
    3. stepper motors or servo motors?
      By jprobst in forum Torchmate
      Last Post: 07-13-2007, 06:37 PM
    4. Motors
      By Jenn in forum Machines running Mach Software
      Last Post: 03-11-2007, 09:54 AM
    5. PWM for AC Motors?
      By vacpress in forum General Electronics Discussion
      Last Post: 03-07-2007, 08:42 PM
