Results 1 to 2 of 2
Thread: Question on Stepper Motor Sizing
    Dec 2010
    Hey All,
    Summary: What size/torque stepper motors do you recommend?
    Finishing the design particulars on a 100" x 50" x 5" Router Table. Construction will be Mostly Aluminum with Linear Ball Bearings. Router will be a Bosch Colt 1hp router. Material to cut will likely be mostly MDF, Hardwoods and *some* aluminum.
    Drives will be 3/8" Pitch timing belts (or 20 pitch rack & pinion). Leaning towards timing belt.
    Realistically looking to cut at 200 inches-per-minute. I'm trying to build for 0.001" Resolution, but realistically would be happy with 0.005-0.010"
    Mar 2003
    Shelby Twp, MI....USA
    Sounds like a G540 with 380oz steppers should work fine. 200ipm should be easyt o achieve, and cutting forces will be very low with the Colt.
    However, I'd question the use of a Colt for such a large machine.
    And I'd expect quite a bit of "bounce" or flexing from 100" of belt.
  1. Stepper Motor Sizing???
    By w102acd in forum Hobbycnc (Products)
    Last Post: 04-14-2009, 11:18 PM
  2. stepper motor sizing
    By diycnc in forum DIY CNC Router Table Machines
    Last Post: 03-23-2009, 09:01 PM
  3. Stepper Motor sizing
    By hanschristopher in forum Stepper Motors and Drives
    Last Post: 03-15-2009, 01:23 AM
  4. Stepper motor sizing
    By Nono in forum Joes CNC Model 2006
    Last Post: 01-14-2008, 11:46 PM
  5. Stepper Motor Sizing
    By itsme in forum Mini Lathe
    Last Post: 12-12-2006, 05:05 PM
