For general discussion, what techniques and methods have ya'll come up with for mounting limit and home switches?
For example, using a typical roller microswitch, do you have a little ramp? are they set up so that machine inertia / overtravel won't run into the switch or are they in the line of fire?
I am seriously looking at the magnetic hall effect sensor based limit and home switch setup from the , though clearly this is not a workable soloution for those that machine ferrus materials, magnets and iron or steel ships do not play well together. For me though, for whom the typipcal materials incluse wood, plastic, and aluminum, hopefully won't be a problem.
LinkBack URL
About LinkBacks
