Results 1 to 3 of 3
Thread: New And Need Help
    Jul 2005
    us
    New And Need Help
    Hi guys I'm new here and have seen the amazing things you can do on your machines and decided that I would also like to build myself a cnc router. Do any of you know where I can get plans for my first machine. I'm kind of on a budget to build this since I just bought a new mill and lathe for my repair shop I decided on the jet for a mill and lathe do any of you have any comments as far as how good of a machine the jet is. I went with a 14/40 gearhead engine lathe floor model and went with the jet 9X49 JTM-4VS for a milling machine. So if I need to do machineing on parts I should be able to do it with the new machines. Im just looking for somthing around a 24x24 or mabye a little bigger that me and my dad can build together and have fun with.
    Thank you and I will say that this is a verry nice placy you have here
    I will also include pictures of the new machines when they get here and are set up.
    Mar 2003
    Shelby Twp, MI....USA
    Jul 2005
    us
    Ok I see the plans for the machine ger21 and that seems simple enough. Now I have worked on machines for several years and they wer all manual machines so CNC is somthing new to me. If I go by the plans and build this machine what will I need to operate it ( Im in the dark on this one) I have a good used computer so I have that and from what I have seen I will go with the stepper motor design for my first machine for money reasons what is the simplest and most economical set up that I can put together for the operation of this machine as far as CNC software that is fairley user friendley and the electronics to drive the stepper setup. Is their a detailed list for electronic dummies like me with instructions of how to build and what to use for the electronic side.
    Thank you and please forgive me for my ignorance ( Im new at this)
