Those rails will be fine with one rail per side, I run the same on my machine and my Gantry is 78lbs(36kg).
What do you plan doing with this machine.?
Had to have a good re think on this r recently, started getting the bits and researching about 3 years ago, and at the time was to be honest thinking more of the technologies and that i could actually own one at home, than the actual practical uses of the machine i was going to build.
I was building custom computers at the time and often needed some engraving done, and could never afford to get al. flat bar milled to create for instance objects like the macbook pro unibody.
So Basically to start with engraving and light milling
lastics and aluminium. though the more i look the more i realise i can do a lot more on the milling side if i have some weight in the frames, and a decent motor spindle.
Those hollow Alu beams will resonate something horrible when cutting anything hard which will produce cutter chatter, I would consider capping and filling them with dry sand or concrete. Esp the gantry.
ive got to admit i was a bit worried about using the box section for the frame and was thinking of someway to reduce the vibration. I bought 5 metres of it about 2 years ago and didnt like to think of it going to waste.
From what i'd read sandwiching metals together (specificly inserting weighted rods inside the box section) would more than likely cause more vibration.
filling them with sand seems like sound advice though this may be impractical, this might do for th etim ebeing until i can aford some profile retrofit framing, or whatever its called.
Dont be put off by the weight, with twin ballscrews you have lots of mechanical advantage and good efficency so with the right size motors they will move far more weight than you probably realise.
Mass is helpfull to a
cnc machine and with this setup you have lots of potential for a really strong well built frame work with a massively strong gantry. . . . Dont chase weight with this setup it's not required and will actually give you a lesser machine with poorer results than the components are capable off providing.!
The long beams will need supporting in the middle else you will get deflection at the centre and even without filling they would still need supporting IMO to prevent sagging due to gantry weight
The plan is to have another 1 meter length in the middle to stop the sag, just havent picked it up yet, i getting the bits as and when i can afford them
. . . . . Being honest this layout of long beams on top of short basicly creating a bridge from end to end is a weak area I would seriously consider changing.
could you expand a bit on this? which way around would you reccomend?or maybe an alternative.
I've got the use of milling machines etc tommorow but have to travel quite a way. if i can get this machine up and running with the bits i have already, then making the necescary changes and drilling holes in a new and improved frame i could do from home a lot quicker
Hope this helps.!
