Depends! I have been doing that for years in TurboCNC as I modified it to use an "auxiliary" Z axis home switch that I can set to the stock Z=0 height!
For any other controller, I cannot answer.
I was reading this thread...
http://www.cnczone.com/forums/diy-cn...s_perfect.html
My question is, Is it advisable to use the pin input for the z homing switch in conjunction with the Z depth input? Can the one input serve both registering home and Z depth?
Thanks!
Art
Guess I should mention that I am using Mach3
If you post this in the Mach3 thread or at Machsupport I am sure you will get many answers.
As far as my opinion, I am thinking that it should work but I am far from an expert.
Tom
The issue that I had was that I needed to daisy chain my home switches in series - and therefore they were normally closed.
The touch plate is as normally open (NO) type circuit so Mach couldn't quite figure out the logic of what was going on since the switches were already closed....
make sense?
Confused..... Were you successful after you chained up your switches?
If it was a single NO switch on the Z used only as a HOME, then you should be able to use a touch plate on the same pin. Grounding the touch plate will act the same as a NO switch being closed - it will pull the pin high.
Well I managed to toast my 6560. Going with a gecko G540.
