Results 1 to 2 of 2
Thread: VSD Servo Drives
    Dec 2009
    VSD Servo Drives
    I have the vsd-e drives from granite devices. I have the motors moving fine, but have some issues with the other functions.
    I want to set up Opto-in 4 for disable / clear fault, but i cannot make the input change state.
    If I put it in non-inverted, the drive is always enabled. Even if i jumper the 5V output to this, it is still enabled. I am unable to disable the drive.
    If i put it in inverted, it is always disabled. This is how i plan to run the drive, but If i put it in this configuration, I cannot enable it.
    Also, I am unsure how to disable the Error recovery function. The last thing I want to happen after a fault, is the motor to move. Anyone know how to disable this? I set the velocity limit for error recovery all the way down to 1, but this can't be the correct way. It still moves, just very slow.
    Thanks for any help.
    Jul 2009
    Sweden
    i recommend that you ask in the Granite Devices forum here on the zone.
  1. Need Help!- servo drives
    By Minnesota HD 10 in forum Bridgeport and Hardinge Mills
    Last Post: 03-29-2009, 07:07 AM
  2. Need Help!- servo drives
    By Minnesota HD 10 in forum Servo Motors and Drives
    Last Post: 03-25-2009, 12:52 PM
  3. servo drives help
    By bbrreid in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 11-09-2007, 03:55 PM
  4. Servo drives
    By quickerz in forum Servo Motors and Drives
    Last Post: 01-21-2005, 11:24 AM
  5. New servo drives?
    By CNCadmin in forum Servo Motors and Drives
    Last Post: 12-25-2004, 09:47 AM
