Page 5 of 25 FirstFirst ... 234567815 ... LastLast
Results 49 to 60 of 290
Thread: New DYI Fixed Gantry Router Build
  1. #49
    Nov 2010
    Quote Originally Posted by DonFrambach View Post
    The parts are 15 series 8020 extrusions.
    The uprights are two 1545 extrusions screwed together.
    The gantry top piece is two 3060 extrusions screwed together.
    The base is made of 3030 extrusions with 1530 cross braces.
    Thanks Don,
    Hard to gauge the sizes from photos alone when you're new to all this :-)
    What's your (and anyone else watching's) opinion on the ability of this rig to cut metals harder than Aluminum? (given the right spindle and tooling of course)
    Cheers,
    Trav
  2. #50
    Registered DonFrambach's Avatar
    Nov 2006
    Got the X axis motor attached. Have almost 14" of X travel. Need to lubricate the leadscrew. Currently can only jog at 15"/minute without horrible sound.
    Have an idea to regain 1 1/2 to 2" of Z travel. I'll replace the bottom bearing block from the Z axis with the smaller one supplied by CNCRouterParts.com. I'll remove 1/4" from the bottom of the block and mount it on top of the steel plate and shift the steel plate down as far as possible.
    photos:
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101119-1.jpg   New DYI Fixed Gantry Router Build-101119-2.jpg   New DYI Fixed Gantry Router Build-101119-3.jpg
  3. #51
    Nov 2006
    Quote Originally Posted by trav View Post
    Cheers,
    Trav
    Don't know. I suppose I'll have to give it a try. I'll be sure to post results.
    Don
  4. #52
    Nov 2006
    It works
    Added an extruded table with T-slots.
    Installed an old Wolfgang Engineering spindle.
    It works!!!
    Need to reverse my X-axis so it doesn't carve everything backwards!
    Need to work out a better hold down system.
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101121-1.jpg   New DYI Fixed Gantry Router Build-101121-2.jpg   New DYI Fixed Gantry Router Build-101121-3.jpg
  • #53
    May 2010
    Don what size linear rails did you use and where did you get that table (did you make it yourself and are you going to surface it?the solid aluminum table not the t slot table i mean)...
    The only reason I ask is because I converted my 5 foot by 7 foot aluminum cnc table over to rack and pinion and with my existing spare parts I can almost build a clone of yours... Although it will not be as re-enforced as yours it will be good enough for printed circuit board work....(i also have the wolf gang 350 spindle)..... Thanks and great work so far...
  • #54
    Nov 2006
    Quote Originally Posted by restless1 View Post
    The X rails are SBR20 rails that I purchased from Glacern but I see that SBR20 rails are available on eBay. The Y and Z rails were purchased from CNCRouterParts.com. I intitially used regular length carriages from CNCRouterParts.com but changed to extended length carriages when I revised (and I think improved) the Z axis as I was building my machine. I used a 7" steel plate for the Y axis and a 4" steel plate for the Z axis.
    the table is a 12x12x3/4 cast aluminum plate (Mic6) that I purchased from MetalExpress.net. The plate is advertised to be flat within .005" but I have not confirmed that.
  • #55
    Nov 2006
    Put the electronics in a box. Also put another box with a switch on the Z axis to power the spindle. That box is under Mach 3 control.
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101127-1.jpg
  • #56
    Nov 2006
    Regained about 1 1/2" of Z travel by replacing the bottom bearing with the smaller one from CNCRouterParts.com. Removed 1/4" of the bottom bearing so that it could be mounted on top of the 1/4" steel plate which was shifted down.
    First two photos show Z travel.
    Third and fourth photos show old bottom bearing and new bottom bearing with the steel plated shifted down.
    Fifth and sixth photos show small bearing supplied by CNCRouterParts.com before and after 1/4" removed from bottom.
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101127-2.jpg   New DYI Fixed Gantry Router Build-101127-3.jpg   New DYI Fixed Gantry Router Build-101119-3.jpg   New DYI Fixed Gantry Router Build-101127-4.jpg
    New DYI Fixed Gantry Router Build-101127-5.jpg   New DYI Fixed Gantry Router Build-101127-6.jpg
  • #57
    Nov 2006
    Put limit switches on the Y axis. Still need to do Zup and X axis. Plan to connect all switches to one input.
    The Z axis can be shortened by about 3 inches. Will get around to that soon.
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101129-1.jpg   New DYI Fixed Gantry Router Build-101129-2.jpg
  • #58
    Nov 2006
    Shortened the z axis by 2 1/2 inches. Could have shortened another inch but was afraid I'd cut off too much.
    Installed a z-up limit switch. Put in series with my Y-axis limit switches. Don't plan on installing a z-down limit switch because I don't think it's necessary.
    Installed an "e-chain". Intentionally a little too long - much better than a little too short. Discovered that my z-axis motor cable is too short. I ordered a longer one from CNCRouterParts but wonder if it would be best to just make a cable so that I can make a cleaner installation as shown at soigeneris dot com or http://www.dyengineering.com/IP40.html
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101205-1.jpg   New DYI Fixed Gantry Router Build-101205-2.jpg   New DYI Fixed Gantry Router Build-101205-3.jpg
    Last edited by DonFrambach; 12-06-2010 at 10:36 AM. Reason: couldn't put in soigeneris web site
  • #59
    May 2010
    Looking very good Don ever thought about proximity switchs...very accurate ...
    What sort of control will you be using...
  • #60
    Nov 2006
    Thanks for your comment. I plan on using the switches only for overtravel. I will zero to my workpiece but may change that as I get a more experienced. At that point more accurate switches may be required.
    I'm using a Gecko G540.
    Don
  • Page 5 of 25 FirstFirst ... 234567815 ... LastLast
    1. New Machine Build- Fixed gantry router
      By KTP in forum DIY CNC Router Table Machines
      Last Post: 04-17-2011, 06:44 PM
    2. Moving table fixed gantry build
      By judleroy in forum DIY CNC Router Table Machines
      Last Post: 12-14-2010, 11:11 PM
    3. Will Build a Moving Gantry ROUTER-comments appreciated.
      By CNCfun&games in forum CNC Wood Router Project Log
      Last Post: 11-21-2010, 01:51 PM
    4. Want to build stout gantry CNC router
      By Jr's Farm in forum DIY CNC Router Table Machines
      Last Post: 10-23-2009, 03:37 PM
    5. Aussie gantry router build number 4
      By Rodm1954 in forum CNC Wood Router Project Log
      Last Post: 08-01-2007, 03:43 PM
