Page 2 of 25 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 290
Thread: New DYI Fixed Gantry Router Build
  1. #13
    Registered acondit's Avatar
    Apr 2005
    Don,
    It is hard to tell from your pictures and since the y, z and spindle aren't yet mounted, but will your spindle be in the center of your X travel?
    Alan
  2. #14
    Registered DonFrambach's Avatar
    Nov 2006
    Quote Originally Posted by acondit View Post
    Don,
    Alan
    I hope it will be very close. I originally planned to make the front and back positioning of the x rails adjustable by about 1.5". I decided to not do that when I went from 4" to 3" steel plates beneath the X rails. I hope that I don't regret that decision.
    Don
  3. #15
    Apr 2005
    It looks like (if you needed to) you could move your whole bridge forward slightly. Is that possible?
    Alan
  4. #16
    Registered ahren's Avatar
    Feb 2004
    Don,
    The construction of this machine looks extremely solid. What are you going to do for your gantry rail? Are you going to extend it past the aluminum on the gantry? My only concern would be that you might have limited travel in this axis. I think everything will be incredibly stiff on this -- I have seen far spindlier moving gantry machines that have made acceptable cuts, so I would personally try to maximize your travel on the gantry.
    Best regards,
    Ahren
    CNCRouterParts
  • #17
    Jul 2003
    california
    festool fan eh?
  • #18
    Nov 2006
    I appreciate all the comments.
    I think that the spindle will be close to the center of my base. Unfortunately, it will be difficult to move the gantry. If necessary, I think that I'll be able to move the X axis rails a little more than an inch.
    I plan to use spacer so that the Y axis can move almost the full length of the gantry.
    A little more progress today. Made and attached small 8020 cuttings to extend the width of gantry. Prepared and attached the 1/4" steel plate to the gantry.
    Some photos:
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101024-1.jpg   New DYI Fixed Gantry Router Build-101024-2.jpg   New DYI Fixed Gantry Router Build-101024-3.jpg
  • #19
    Nov 2006
    Painted the steel on the gantry and the steel support for the X rails. Mounted the completed Z axis onto the Y axis. The stepper motor has not been connected. The photos below show the potential travel on the Y axis. The third photo shows the spacer I inserted to increase the Y travel. The X axis rails are not currently attached.
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101024-4.jpg   New DYI Fixed Gantry Router Build-101024-5.jpg   New DYI Fixed Gantry Router Build-101024-6.jpg
  • #20
    Nov 2006
    It doesn't show well in this photograph but the Z axis does not have a whole lot of usable travel unless I greatly extend the plate that I purchased from CNCRouterParts.com. A much better solution would be to have the two sets of bearing blocks mounted back-to-back on a single plate. That way the set up would be much more rigid and have much more usable travel without cantilevering the cutter way below the bearings. CNCRouterParts.com just started selling a mounting plate to just that. (http://www.cncrouterparts.com/produc...roducts_id=101) I think I will make a plate that incorporates the spacers that I need to maximize Y axis travel.
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101024-7.jpg
    Last edited by DonFrambach; 10-25-2010 at 11:38 AM. Reason: added link to part from CNCRouterParts.com
  • #21
    Dec 2006
    Did not see page 2 before I responded..oops
    Don,
    Looking real nice, please keep the pics coming.
    Thanks for sharing,
    Tom
    Last edited by DeadTom; 10-25-2010 at 10:35 AM. Reason: Came to the party too late
  • #22
    Apr 2007
    Hi, nice stiff build - I am a big fan of fixed gantry setups.
    I used 2 sets of bearing trucks to get the extended length stiffness, but on a 4x8 router.
    You can go much longer with that plate and still be ok. cncrouterparts also makes a single longer truck.
    Z axis travel is important for work - don't cut yourself short on it.
  • #23
    Oct 2005
    That's looking very respectable so far Don. Had you considered turning that Z plate upside down, so its side bearings are lower and closer to the tool (ie less deflection). Of course that depends on the length fo the spindle and tool.
    On my machine I used a drilled plate with 10mm grid, so I can easily lift or lower the spindle by screwing it on at a different height, then set the max Z travel at 60mm. The result is that there is very little deflection distance when using short tools (as you do for heavy cutting) but if using long tools etc I can just re-mount the spindle higher up and still keep the bearings low and close to the cut for max rigidity. Hope that makes sense.
  • #24
    Nov 2006
    Made the plate to allow the carriages to be mounted back to back. The first two photos show different views of the plate.
    Mounted the plate using extended carriages available form CNCRouterParts.com. This reduced the Y travel from a theoretical 16 to a potential 14 inches. The potential travel is shown in the next two photos.
    I then mounted the Z axis to the plate again using extended carriages. This severely reduced my Z travel to a little less than 2 inches. I'm going to get another steel plate to increase the Z travel but I haven't figured out how much I'll need.
    Oops!, booboo shown in the last picture. I forgot to account for the height of the screw heads holding the Z carriages in place. I'll need to make a small relief in the plate for the two middle screws. darn!
    Attached Thumbnails Attached Thumbnails New DYI Fixed Gantry Router Build-101031-1.jpg   New DYI Fixed Gantry Router Build-101031-2.jpg   New DYI Fixed Gantry Router Build-101031-3.jpg   New DYI Fixed Gantry Router Build-101031-4.jpg
    New DYI Fixed Gantry Router Build-101031-5.jpg   New DYI Fixed Gantry Router Build-101031-6.jpg
    Last edited by DonFrambach; 11-02-2010 at 12:45 AM. Reason: corrected z travel from less than 3 to less than 2 inches
  • Page 2 of 25 FirstFirst 1234512 ... LastLast
    1. New Machine Build- Fixed gantry router
      By KTP in forum DIY CNC Router Table Machines
      Last Post: 04-17-2011, 06:44 PM
    2. Moving table fixed gantry build
      By judleroy in forum DIY CNC Router Table Machines
      Last Post: 12-14-2010, 11:11 PM
    3. Will Build a Moving Gantry ROUTER-comments appreciated.
      By CNCfun&games in forum CNC Wood Router Project Log
      Last Post: 11-21-2010, 01:51 PM
    4. Want to build stout gantry CNC router
      By Jr's Farm in forum DIY CNC Router Table Machines
      Last Post: 10-23-2009, 03:37 PM
    5. Aussie gantry router build number 4
      By Rodm1954 in forum CNC Wood Router Project Log
      Last Post: 08-01-2007, 03:43 PM
