Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Vectric Cut2d output to Mach3
    Registered msimpson99's Avatar
    Aug 2010
    I can generate gcode files that mach3 can read but the "Output direct to machine" does not work. I get the following two errors:
    "Failed to find data on installed version of Mach"
    "Failed to find running instance of Mach"
    Has any one gotten this to work?
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Question
    msimpson99,
    What version of Mach3 are you running?
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Aug 2010
    I just downloaded it less than a month ago.
    Aug 2005
    UK
    Hello msimpson99,
    The Vectric software will automatically send the toolpath data to that version.
    Mach3 needs to be running before saving the toolpath.
    The link is not designed to actually start Mach3, only load / open the the toolpath data into a running instance.
    If you continue to have a problem with this please email - support at vectric.
    Tony
    Dec 2006
    As Tony stated, start Mach first then do your output to Mach.
    It works flawlessly on my system.
    Tom
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Hello msimpson99,
    This option does work with the latest version of Mach3 as Tony has stated, and I have used this option but wanted to clarify that the computer running the Vectric software is also connected to the machine and being used as the controller and Mach3 is already running and ready to receive the file. After sending the file it should be found loaded into the Mach3 program and ready to run.
    Regards,
    Wes
    Aug 2010
    Before I even made this post I had the both pieces of software up and running on the same computer. Windows 7 OS 32 bit.
    IT does not work.
    Oct 2006
    Modesto, CA U.S.A.
    Quote Originally Posted by msimpson99 View Post
    IT does not work.
    Hello,
    I did not realize what system you were running, and I am using Win XP on the system connected to the machine, so it works for me but I am not doing it with WIN 7. I did try to send a file from my WIN7 system although I don't have Mach3 installed on this system and I received the same errors you mentioned. Makes me think your system is not allowing the Vectric software to connect to Mach if it is running on the same system. Hopefully someone running WIN7 and using the direct connect feature will respond.
    Regards,
    Wes
    br1
    br1 is online now
    Oct 2006
    Although it is susposed to work, The only way I have had good luck is to save the code fron cut2d to a seperate folder then in Mach3 load the code from that folder, this is what someone suggested and it has worked good. I had the same problem and I feel your right that the "Output direct to machine" does not work correctly. I got the same errors, No one ever responded as to why this happens, perhaps they did respond and I missed it.
    Aug 2010
    -- It was late and I was venting and since the rant in this entry has little to offer. --
    Last edited by msimpson99; 09-23-2010 at 07:00 PM. Reason: Original comments were not productive
    Aug 2005
    UK
    Hello Michael,
    Your order has been refunded in full and you should have received an email confirming this.
    I guess you have seen our reply on the Vectric Forum explaining that Mach3 is not creating the required entries on Windows 7, so the Vectric software cannot make the link. We will contact Mach3 to see what can be done to resolve the issue.
    Apologies for this inconvenience, but we were completely unaware that there was a problem with Mach3 creating the required information on Win7. (br1 – did you contact Vectric directly about this issue?)
    Tony
    To reply to your other concerns.
    We recommend exporting files from Corel Draw as EPS – See the FAQ page >
    There is also information on the same page about working with DXF files.
    For reference - I have checked with our Technical Support Team and we don’t appear to have received any previous correspondence from you on this or the file import issues.
    The quickest and easiest way for customers to get answers to questions is to contact Vectric Support – support [ at ] Vectric [ dot ] com
    We are 150% behind our products and make every attempt to thoroughly test and verify that the software works as advertised. But sometimes this stuff happens and we will do our best to assist customers.
    Aug 2010
    Last edited by msimpson99; 09-23-2010 at 06:59 PM. Reason: Not reflective to issue at hand
  • Page 1 of 3 123 LastLast
    LinkBacks (?)
    1. 03-26-2013, 06:42 PM
    2. 03-26-2013, 06:01 PM
    1. Direction output inverted in Mach3 R3.041
      By kreutz in forum Machines running Mach Software
      Last Post: 07-21-2010, 08:18 PM
    2. Help with Mach3, Vectric
      By oldskimmer in forum DIY CNC Router Table Machines
      Last Post: 06-30-2009, 04:53 PM
    3. G CODE NOT WORKING ANYMORE from Vectric cut2d and 3d
      By TZak in forum LinuxCNC (formerly EMC2)
      Last Post: 03-01-2009, 10:51 AM
    4. Which Rhino output for Mach3 mill?
      By BEIGeorge in forum Machines running Mach Software
      Last Post: 01-11-2008, 04:47 PM
    5. Help needed to customize output of Mach3
      By frenzal in forum Screen Layouts, Post Processors & Misc
      Last Post: 10-15-2006, 09:25 PM
