Results 1 to 2 of 2
Thread: Very confused ... HELP
    Apr 2010
    yda
    sorry for to post very close to the same but more i read more i get lost.
    I have read several post on this site
    Ok im looking at
    these
    Product Line: Hi-LeadŽ
    Major Diameter: 1/2" (in.)
    Threads Per Inch: 6 (Threads/in.)
    Number of Starts: 2
    Lead: .333 (in./rev.)
    Effective Threads Per Inch: 3 (Effective TPI)
    Hand: Right Hand
    Threads Per Inch: 8 (Threads/in.)
    Number of Starts: 2
    Lead: .250 (in./rev.)
    Effective Threads Per Inch: 4 (Effective TPI)
    Hand: Right Hand
    Threads Per Inch: 10 (Threads/in.)
    Number of Starts: 2
    Lead: .200 (in./rev.)
    Effective Threads Per Inch: 5 (Effective TPI)
    Hand: Left Hand
    Number of Starts: 4
    Lead: .500 (in./rev.)
    Effective Threads Per Inch: 2 (Effective TPI)
    Hand: Right Hand
    any suggestion on which of these to use
    my mill is 495 in steppers
    on smc bearings / rails
    cutting plastics
    i want to increase the speed but will it 'LOAD UP' the motors alot if i go to higher TPI?
    size of the table is 30" by 33"
    as in previous post. my current screw is all thread 12 TPI using a 2 " aluminum block threaded all 2 inches.
    i would love some input want to order very soon.
    my current use able TPI for cutting is about 38 , rapid is 55 ish inch per minute
    like to get cut speed to 85 to 100 and rapid to about 130+ inch per minute
    thank you for your help bob
    Aug 2006
    canada
    Hi again, ok the 8 tpi 4 start .500 will be you fastest hi lead you asked about. it will be 2 turn per inch of travel. You still get good resolution. But you also have to think about your drivers. Also you said you are working with plastic, delrin (spelling) I think you said, why not make your own nuts. you can use a piece of the lead screw to make a tap with.delrin would be better than metal I think. less wear on your screws. I think Roton sell's the plastic ones as well. I've been using nylon on mine and still has no slop. Graham
  1. Need Help!- I'm confused
    By FUBAR62172 in forum General Electronics Discussion
    Last Post: 04-20-2010, 05:58 PM
  2. Need Help!- Bit confused
    By nenetwork in forum General Electronics Discussion
    Last Post: 03-09-2008, 02:07 PM
  3. Confused
    By Gingah in forum Joes CNC Model 2006
    Last Post: 01-17-2008, 02:49 PM
  4. confused???
    By johnm99 in forum TurboCNC
    Last Post: 02-16-2006, 05:35 PM
  5. A Little Confused??
    By BuckingFastards in forum DIY CNC Router Table Machines
    Last Post: 02-08-2006, 06:20 PM
