Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: crap.....
    Apr 2009
    crap.....
    Well, that isn't good. 8020 Inc Standard T Nut Profile 15 S 8900 x 36 N was easy to center punch and drill.... but tapping... eh... crap.
    Pencilneck blah blah blah
    http://tinyurl.com/22lqgvv <=== My CNC Mill build thread
    Nov 2004
    Maybe some dry ice, a ball-peen hammer, and some focused rage will get that out...
    Hate when that happens!
    Apr 2006
    na
    Quote Originally Posted by spoiledbrat View Post
    grind one side flat.. get a goood centre punch layout out on it
    get a1/8 bit and larger (high quality cobolt drills) and drill babie ....
    drill ...it out... cobolt drills bit is your only way.... to drill thew it use lots of lub, and use several drill bit size one by one till u drill thur it. rest will crumble away.
    unless you can grab the back side with viice grips and heat it with torch? and unscrew it?
    Registered Regnar's Avatar
    Mar 2006
    It looks like you might have leaned it to far over when tapping. Usually what happens from over torquing is the tap breaks right at the hole opening. Try grabbing with a set of pliers and twisting back and forth.
    Are you using some kind of tapping lubrication? Part looks a little dry.
    Make sure you drilled a hole for steel and not aluminum. You want 50% thread http://www.nolansupply.com/tapdrillchart.htm
    Just a little teaser but I have done over 300 holes now with no problems on the same tap.
    [nomedia="http://www.youtube.com/watch?v=_XLGCt5UQGM"]YouTube- ‪Easy Tapping Method‬‎[/nomedia]
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    What about hacksawing a slot in the end and using a screwdriver to get it out? Heating the bar will expand the "hole"
    I love deadlines- I like the whooshing sound they make as they fly by.
    Aug 2007
    If you have enough threads exposed on the bottom side. spin a nut on it and very carefully tack it in place, set the welder as low and "cold" as possible. Should be able to turn it right out.
    Hope that helps ya
    Mike
    Registered fatal-exception's Avatar
    Mar 2006
    Quote Originally Posted by Med-Pac View Post
    Sounds like a good idea, but I've never had luck with that...
    You could try to drill with carbide, but you need a very rigid machine to do that. If you can't drill it, try to shatter what remains with a punch and hammer, then extract the bits with pliers.
    Every broken tap is different....
    Paul
    Nov 2004
    That welding idea is super clever.
    Rob
    Apr 2003
    You don't have any real problems. Grind it off from both sides and then use a small grinding point (even a dremel tool) will work to grind the web out. The rest will fall out or be easily picked out. A good carbide drill would more than likely drill it out but if you break it off you just have more to grind out.
    Registered arizonavideo's Avatar
    May 2008
    I did about the same thing a few weeks ago with the last hole in a Z plate.
    I ground it flat and tried a drill bit but all failed. I ended up clamping it to the router table and using a 1/8" carbide EM in a drilling peck operation. Slow but it worked fine.
    Mar 2007
    england
    No one near you that does spark eroding?
    Jun 2006
    looks like you have enough out the bottom to grab with vise grips and back it up. No?
  • Page 1 of 2 12 LastLast
    1. Is this collet CRAP ???
      By Frogblender in forum General Metalwork Discussion
      Last Post: 09-04-2009, 01:37 PM
    2. Evil, Awful, Hateful Crap!
      By jim_stoll in forum Benchtop Machines
      Last Post: 11-15-2007, 05:15 PM
    3. Does anyone ever get this CRAP???
      By rodneydeeeee in forum CNCzone Club House
      Last Post: 06-11-2007, 05:08 PM
