Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Drifting X-axis, making step ladders one side whereas other side is smooth- SOS
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    Recently i have retrofitted Radial drill machine and currently having an issue with 'drifting' + in the X axis. I have a work piece on which i have drill some holes and then profile milling upto 4mm deep with 0.5mm DOC per pass... After centre drilling and final drilling of 7mm dia drill 4mm deep, i started milling with 3-flutes 6mm end mill... After 1 Hour the job was finished and the end mill went to its zero position about 2mm toward the positive X-axis...
    I saw the profile and i found step ladder (each pass with little drift toward X) toward one side whereas i have removed material from the other end...In several levels in Z I can see by the faces of the pocket that it drifts (steps on one side, smooth on the other).. This figure will depend upon the length of program run, longer program, bigger drift. Any ideas?
    I have backlash compensation On.
    The computer is dedicated to Mach software only.
    Material SS-316 solid bar
    Depth per pass= 0.5mm
    Feed: 2IPM
    Dormer end Mill HSco 3-flutes
    Spindle Speed= 800 RPM
    Ramping
    Kind regards
    Khalid
    Attached Thumbnails Attached Thumbnails Drifting X-axis, making step ladders one side whereas other side is smooth- SOS-final_part1.jpg
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Apr 2006
    Pakistan
    Any thoughts?
    Apr 2007
    Quote Originally Posted by Khalid View Post
    Any thoughts?
    Hi Khalid,
    I had a very similar problem when I tried cutting aluminum on my second machine. The gcode did the same thing, to a lesser degree when I tried it on my 25x37 machine. Both machines do not have the problem if I run the gcode using EMC2/Ubuntu Linux. I have not spent any time trying to determine why Mach3/Vista has this problem, but I can say that the Vista computer also has EMC2/Ubuntu as a dual boot setup and the problem is related to Mach3 and/or Vista, not the Acer computer's hardware.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2006
    Pakistan
    Hi CarveOne,
    I am running Mach3 on Win XP... I get electric shock when touching the controller panel.. Is this a cause?
    Mar 2009
    Howdy,
    I had a similar problem too. Check to see if the bottom of your cut (from the inside edge of the last step to the other side) is the correct distance. I did a bunch of pocket cuts till I got the problem corrected.
    The solution I had given to me, was to input larger step and direction pulses in Mach under motor tuning. I had to get mine up to 17-19 in each to get rid of it. What the max setting you can put in each and what not I don't know. Also I don't know what determines what is the max. It seems to vary sometimes and mach sets it lower after I input a different number.
    I can not say whether this is noise or not enough power coming from your printer port (I'd like to know the reason as well), but this seems to fix the problem.
    Hope this helps, GL!
    Jordan
    Dec 2003
    Hi CarveOne,
    I am not sure what the supply method is in Pakistan, but it would seem you do not have the machine properly grounded, You should not receive a shock, what ever system is used.
    Not safe the way it is.
    Also ground issues can cause havoc with PC based systems especially.
    Apr 2006
    Pakistan
    Quote Originally Posted by Al_The_Man View Post
    Al, I will redo all wirings and make the machine and control panel ground tomorrow... Safety First ...
    One possibility can happen in this step ladder cause.. If i have wrongly entered the backlash compensation for X-axis in Mach3.. Could it cause the step ladder formation for each pass? Lets suppose the actual backlash is 0.2 mm and i entered it 0.1mm.. will i get a step ladder effect then?
    Apr 2006
    Pakistan
    Quote Originally Posted by Realmseeker View Post
    Howdy,
    Jordan
    Okay... This is good point.. When i put 5 in step and direction pulse, Mach make it 3 and sometime to 1... I don't know why... I will try 1/2 step sherline mode tomorrow... will show you the results...
    Apr 2007
    Hi CarveOne,
    Al_The_Man has already answered this question and I will agree with him. Getting shocked or even a little tingle is a sign of wiring problems that need to be corrected as soon as possible. Electronic equipment will not work reliably with improper grounding.
    Mach3 runs best with Win XP or XP Pro. Unfortunately, I gave away my only Win XP Pro computer and bought a new computer with Vista Business Edition. The new computer running Vista and Mach3 is having the step over problem, unless I reboot the new computer and load Ubuntu/EMC2 instead.
    CarveOne
    CarveOne
    Apr 2009
    Check if your z axis is perfectly perpendicular to the surface, and that it doesn't drift as it moves up and down...
    Apr 2006
    Pakistan
    Quote Originally Posted by louieatienza View Post
    Thats a really nice point... You mean for each pass depth Z-axis may add some drift... But why in only one direction?...
    I am using Quill as Z-axis and i have 0.2mm clearance between the spindle quil and the Bush...
    Apr 2006
    Pakistan
    Today I checked all of the wiring.. The problematic X-axis wiring , i have found short circuit situation.. The 6 wires coming out of Logic MOSFETS... The connect at the Motor power wire was darken due to continuous arcing... I think this may be the problem..
    One of the motor coil was getting uneven voltages due to this arcing short circuit.. I don't know the right term... Is this may be Problem?\
    Any Thoughts? How can this cause drifting of axis one side?
    PS:
    I also increased the Pulse width and ran it with 1/2 pulse sherline mode, but the problem was not solved...
    Before opening the controller i checked whether the problem in the axis?.. For this i calibrated the X-axis , but every time i got drift toward positive X-axis.. As this was done during the calibration, so no cutting forces and no Quill clearance plays any role here...So the drifting was totally not related to mechanical... Then i swap the Y-axis motor with X-axis, and i always got the results within 0.03mm range for the same axis.. This means i have no mechanical problem..
    Attached Thumbnails Attached Thumbnails Drifting X-axis, making step ladders one side whereas other side is smooth- SOS-problemconnector.jpg
  • Page 1 of 2 12 LastLast
    1. Z-axis - mounting rails on spindle side, rather than tower side
      By guru_florida in forum Linear and Rotary Motion
      Last Post: 01-31-2008, 07:54 PM
    2. linear slides X-axis single side or dual?
      By PlasmaGuy in forum Linear and Rotary Motion
      Last Post: 02-16-2006, 12:44 AM
    3. mounting linear rails side by side
      By 50062040 in forum Linear and Rotary Motion
      Last Post: 10-24-2005, 08:49 AM
    4. 4th axis with side of tool ?
      By Passenger in forum OneCNC
      Last Post: 07-13-2005, 03:53 PM
    5. 4 axis edm side
      By j03man in forum FeatureCAM CAD/CAM
      Last Post: 06-29-2005, 04:39 PM
