Results 1 to 2 of 2
Thread: Rotation along the y axis?
    Jun 2010
    Having some crazy thoughts about building a 6 axis machine. I'm thinking of rotation then entire y axis. Will this work? Can any software control such movement in a useful manner?
    Registered jsheerin's Avatar
    Aug 2008
    Yes, you could do this (rotate the entire part around the y axis). This is a common setup for 4 and more axis machining. Mach 3 could control this if your cam software could generate the code. That is usually the tricky part - the cam.
  1. VH 65 A axis rotation
    By timo2le in forum Fadal
    Last Post: 11-11-2009, 11:16 AM
  2. B axis rotation
    By fitzpatrick2362 in forum General Metalwork Discussion
    Last Post: 10-12-2009, 07:06 AM
  3. Rotation control help on A axis
    By Art Ransom in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 08:04 AM
  4. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-17-2006, 09:36 PM
  5. Converting X axis to A rotation
    By quemast in forum GibbsCAM
    Last Post: 06-09-2006, 11:17 AM
