Results 1 to 5 of 5
Thread: 1/2" 5-start for Z-axis?
    Nov 2007
    Going to be ordering some parts soon and I'm using 1/2" 5start for X and Y. The acme rod I'm getting locally come in 6ft. lengths so there will be enough left over to use for the Z axis. Is there any issues with this or should I be using a finer thread?
    BTW My machine will probably be a mish-mash of the JGRO, Joes2006, etc. machines and I will be mounting a bosch colt router. Also a G540 drive and 381oz steppers.
    Thanks.
    Apr 2007
    Quote Originally Posted by Biff View Post
    Thanks.
    There are no problems with 5 start on my two Z axis assemblies. It's a little quick if you only have 4.5" Z travel and you have 250 ipm manual jog speed though. You can slow it down in Mach3 or EMC2.
    I like having X,Y, and Z the same on one machine. I use R&P X and Y with 5 start screw Z on my other machine.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Nov 2007
    Thanks,
    I did some digging and found a thread from a couple years ago that pretty much says the same thing. It was mentioned that there was the possibility of back-drive when the machine was shut off so I'll just have to be aware of that... or use a spring.
    Apr 2007
    Thanks,
    I'm not having any problems with that at all. The weight of my router and the moving part of the Z axis is about 10 pounds. If you are using a very heavy spindle and your Z axis moving parts are mostly steel you might have some reason to worry.
    CarveOne
    CarveOne
    Apr 2009
    I have 1/2"-8, 8 start (1 TPI or 1" lead) on my machine (otherwise similar to CarveOne's small Solsylva machine) and have not had problems with backdriving. I don't have the heaviest router mounted, but with the stepper and AB nut attached, there seems to be enough "hold" when the machine is off. Once the machine is on, I'd probably flex my machine before the screw backdrives....
    I also set the jog speed on the Z a lot slower, 120IPM on the Z and 350 on the X/Y....
    1. Lets Start 3-axis "khattak Mill"
      By Khalid in forum CNC Wood Router Project Log
      Last Post: 01-14-2011, 05:37 AM
    2. Using "Q" on G32 for multi start threads
      By Species8472 in forum GibbsCAM
      Last Post: 12-29-2008, 09:17 AM
    3. Need Help!- Powermax 1000 intermittent "no start" problem
      By MoparJon in forum General Waterjet
      Last Post: 12-17-2008, 03:59 PM
    4. uncontroled start of spindle when "z" home.
      By bcbackoader in forum 5T/5M
      Last Post: 10-16-2008, 07:37 PM
    5. 4020 fadal cant get past "Cold Start"
      By chipsahoy in forum Fadal
      Last Post: 03-07-2006, 07:29 PM
