Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: What is the distinction between SBR and TBR linear rails?
    Nov 2009
    I can't seems to find an answer anywhere online. I asked in FAQ of CNC building subforum but I don't think the post was ever approved. The drawings make it appear the SBR rails have a smaller opening which would make them more appropriate for mounting with a 90 degree rotation on the rail. Any thoughts?
    ANSWER EDIT:
    quote from gio666
    the SBR is smaller , thinner , and is the cheap version of supported rails , as why they sell them for same price as TBR as people don't know there not the same
    May 2005
    canada
    That's a good question and Google is not your friend ! I asked the same thing and received no answer.
    linearmotionbearings sbr rails
    If you read the follow up in the link above you'll see the conclusion I reached by comparing Linearmotionbearings products. If someone has a better definition please share.
    Anyone who says "It only goes together one way" has no imagination.
    Gold Member eaglezsoar's Avatar
    Feb 2010
    Regards, Carl
    May 2005
    canada
    That link comes back to my posts and the information I provided was a guess at best.
    I'll try getting an answer from Chai (LMB) but he doesn't always respond on weekends. Maybe someone will provide a definitive answer before then.
    May 2005
    canada
    According to Chai (linearmotionbearings2008 on Ebay) the ONLY difference between TBR and SBR is the mount hole spacing. He sells tons of this stuff so theres your answer. His store will no longer carry the TBR items btw. The TBR items he currently lists are a different design but the TBR/SBR designation has nothing to do with it.
    Company Representative gio666's Avatar
    May 2008
    SBR20 LEFT AND TBR20 RIGHT ,SBR is the cheaper of the bearings and rails .
    as i have tons of the railing
    May 2008
    May 2008
    TBR allows you to use larger bolts and fit most of the 8020 , SBR rails don't fit much of the 8020 profiles ,
    also get more clearance with TBR
    Nov 2009
    Thank you! Awesome and informative pictures
    May 2008
    SBR bearing housing on TBR rails
    May 2008
    Quote Originally Posted by cyclestart View Post
    the guy Chia (linearmotionbearings2008 on Ebay) seams to tell alot of people wrong stuff about products , mostly to sell products he has , lots of info is inaccurate about the rails ,bearing and mostly the ballscrews
    May 2008
    there lot of pictures on TBR rails on this thread
    DIY Aluminum cnc router Frame
  • Page 1 of 2 12 LastLast
    1. What is the distinction between SBR and TBR linear rails?
      By pswayze in forum Mechanical Calculations/Engineering Design
      Last Post: 05-26-2010, 03:44 AM
    2. Thomson Bars, V-Rails, or Linear Rails
      By Chuck_M in forum Linear and Rotary Motion
      Last Post: 12-18-2009, 03:39 AM
    3. Newbie- linear rods versus linear rails
      By haylspa in forum Benchtop Machines
      Last Post: 08-11-2009, 09:44 PM
    4. Linear bearing spacing & Sizing linear rails?
      By fyffe555 in forum DIY CNC Router Table Machines
      Last Post: 12-07-2004, 02:09 PM
    5. Linear rails, rod which is better for cnc?
      By snokid in forum DIY CNC Router Table Machines
      Last Post: 12-29-2003, 08:12 PM
