Results 1 to 11 of 11
Thread: Need help identifying large bipolar stepper motors
    May 2010
    Hello,
    Can anyone help me identify these motors.
    Sigma pacific scientific
    Bipolar stepper motor 4 wire NEMA 34
    Model number 21-3437d200-B038
    phase resistance 0.5 ohms
    phase inductance ~680 mh
    Date code 8921
    I have 3 of these and would really like to use these steppers for a cnc router. Thanks for any help you can provide.
    May 2010
    21-3437d200-B038 Identified!
    I had to call target electronics and have someone look up the model in an old catalog from 1989.
    Break down of model number
    21-3437d200-B038
    21 is the motor series
    34 is the frame size NEMA 34
    37 stands for 2 stack
    d200 is the number of steps per revolution
    B is a four wire motor
    038 is the phase resistance
    Modern model number is H32NRHA-LNN-NS-00
    Phase current 5 Amps
    Phase resistance 0.38 ohm
    Phase inductance 0.38 mh I did fry my multimeter after all damn it
    Holding torque 460 oz-in
    I hope this helps someone.
    Feb 2007
    CUBA
    Hello, Iam building a cnc embroidery machine, work is detailed here
    DIY- CNC Embroidery Machine
    I have three stepper motors, from Panasonic dot printers. I don’t have information about volts, amps and electrical wires connections.
    Steppers are
    1-PJJQ113ZA-P Matsu****a line feed motor
    36 Omhs Japān
    Panasonic printer KXP1624.
    7.5Deg/step
    48 pasos/rev
    2-PJJQ92ZB-P Line feed motor with brass gear
    PANASONIC DOT PRINTER KX-P1124 line feed
    Resistance (Ohms) 9.5
    Wires 6
    Steps / Revolution 48
    Step Size (degrees) 7.5
    Gear Diametrial pitch 50
    3- PJJQ114ZA-K Kyushu Matsu****a electric Stepper with optical wheel & cog
    Nominal Voltage 3.1
    Resistance (Ohms) 3.4
    Wires 6
    Condition pulled
    Steps / Revolution 200
    Step Size (degrees) 1.8
    I need to know if I can connect it in a CNC controller with a 33VDC power source.
    I need to know amperes for these motors for set Vref in CNC controller.
    I need to know about torque, to see if is enough for project.
    Thanks in advance for any help than can give me.
    Sorry my bad english
    Regards
    Rene
    Registered kennyd's Avatar
    Nov 2011
    Quote Originally Posted by thatguy666 View Post
    Yes, it certainly helped me! I have three of these on a Bridgeport I recently acquired.
    https://picasaweb.google.com/1139665...ridgeportPart2
    Did you get your router built? If so what voltage are you running them at?
    May 2010
    Hello,
    My CNC is a work in progress. Perhaps in a few months I'll be done.
    I believe I was running the motors at 40 volts.
    I wouldn't mind having a Bridgeport in the meantime.
    Nov 2011
    Thanks for the reply, Any chance you can recall why the big difference in the specs you posted above? Particularly the mh numbers of ~680 and then 0.38
    May 2010
    Yea, one of the inputs on my multimeter was fried by one of my friends.
    The measurements in the second post should be correct. I can check them out later to confirm.
    Nov 2011
    That would be great...
    May 2010
    Alright.
    I was finally able to get those measurements.
    Phase inductance is really around 3.95 mh. No one notices an order of magnitude difference!
    The phase resistance is ~0.4 ohm. I can't find my analog meter so I can't give you a more accurate measurement.
    BTW the voltage isn't all that critical.
    Cheers
    Nov 2011
    Thank you very much!
    My system is running at 20 volts as recieved and that semms pretty low-just trying to get close to a better number to run the motor's at.
    I also can't seem to get above 25 ipm very well...still learning
    Mar 2006
    Chinese 4 axes mini mill
    1. Need help identifying motors
      By Pukwudji in forum DIY CNC Router Table Machines
      Last Post: 03-04-2011, 06:57 PM
    2. Build Thread- A 150V 8A Driver design for Bipolar Stepper Motors
      By baggs in forum Open Source Controller Boards
      Last Post: 07-12-2010, 07:56 PM
    3. Help with identifying stepper motors
      By viroy in forum Stepper Motors and Drives
      Last Post: 05-08-2008, 01:19 AM
    4. Source of large stepper motors?
      By Jim Estes in forum Stepper Motors and Drives
      Last Post: 02-03-2008, 02:07 PM
    5. testing bipolar stepper motors from ebay
      By cowanrg in forum Stepper Motors and Drives
      Last Post: 07-14-2005, 02:11 PM
