Results 1 to 4 of 4
Thread: ball screw lubrication...
    Registered Chris D's Avatar
    Apr 2005
    Greetings all,
    I have the 5/8" rolled ball screws on my machine and they work okay. However, they will bind up from time to time and I just squirt a little silicone spray lube on them and it seems to be okay again for a while.
    I would like to use regular oil but I know that the dust would collect on the screws and turn them into "Chia pet" looking things.
    Does anyone have any recomendations for ball screw lubricants?
    TIA
    Chris
    Gold Member
    Jun 2003
    I am using way oil on mine, I got my way oil from mcmaster and it works great, super smooth. I have had them spinning near 1050rpm with no complaining.
    Jon
    Apr 2005
    How do you keep all the wooddust from sticking to the screws?
    Chris
    Quote Originally Posted by JFettig
    Jon
    Mar 2003
    Shelby Twp, MI....USA
    He doesn't use it on a wood cutting machine.
    Try mounting some brushes on each end of the screw to keep it clean. Or, check if there are seals available for the nuts you're using. Some people here have made seals by applying a bead of hot melt glue to the nut. With the screw oiled, the glue won't stick to the screw, only the nut.
  1. Revolutionary Linear Drive System
    By allanconway2 in forum Polls
    Last Post: 02-12-2013, 02:39 PM
  2. Ball Screw Identification
    By BeerFizz in forum Benchtop Machines
    Last Post: 04-07-2005, 11:28 AM
  3. Need help with Ball Screw Choice
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-06-2004, 08:02 AM
  4. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 09:49 AM
  5. Ball screw size/pitch?
    By jakk100 in forum DIY CNC Router Table Machines
    Last Post: 06-18-2003, 11:21 AM
