Results 1 to 7 of 7
Thread: Little Machine Shop Spindle
    Mar 2010
    http://littlemachineshop.com/product...ory=-269978449
    Hi guys,
    What do you guys think about this? I will only have access to 110V power, so 220 V is out of question.
    The intended use will be for hobby CNC milling on a 12"x12"x6" desktop mill w/ a moving table. Nothing too fast, it is not really that important.
    I like how the low and high speeds are in a good range for milling metals, but I'm not sure if it has enough power?
    I really wanted to get the chinese spindle at first, but I don't have access to the 220V power at the moment.
    Also, I dropped them an email to ask them about the runout of the system, so we'll see how good it is
    Oh yeah, R8 or 3MT? All I know is 3MT is more permanent and meant to stay in there unless I wanna hammer it out...
    The last option would be to get a strong AC motor and manually make a spindle for it, but if time runs out, I'll be getting this instead to save time and frustration.
    thanks!
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Thumbs up
    Rontruong,
    Have you seen the work Hoss2006 has done with the X2?
    No doubt very capable for what it is.
    http://www.hossmachine.info/
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2010
    WOW, great thanks for the good source!!
    Apr 2007
    Get the R8 spindle version. There is much more tooling available for it at low prices. R8 tooling requires a light hammer tap on the jack screw that holds it into the spindle also.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Oct 2009
    runout
    Check reviews at www.mini-lathe.com for runout examples.
    lathe and mill spindle have similar construction and runout.
    Mar 2010
    great thanks for the review link!
    I figured r8 was better, thats what we use at school I think.. looks very similar
    Mar 2010
    so from looking at hoss's website and all prices... it seems like its a lot cheaper to buy an X2 and work off that...?
    what do you guys think....?
    I was summing up buying the column and the spindle assembly... and making my own x-y stage.. but it'd probably come close to the cost and take more time...
    1. The Little Machine Shop
      By digitalmdj in forum Mini Lathe
      Last Post: 06-14-2009, 01:09 PM
    2. Use Machine Shop vs. Buying Machine
      By imp22b in forum General Metalwork Discussion
      Last Post: 06-06-2007, 07:33 AM
    3. New CNC machine shop
      By chuy in forum Employment Opportunity
      Last Post: 10-13-2005, 10:52 PM
    4. CNC Machine Shop
      By emiljbd in forum Employment Opportunity
      Last Post: 07-05-2005, 03:22 PM
