Hi All,
My machine is almost done, just need to fabricate a holder for the dremel and some final tuning and i'll be ready to do my first cuts.
what are the basic bits i should get for working with balsa,plywood,mdf,plastics,and maybe aluminium.
i will mostly do parts for my RC stuff and other small projects.
so i would like to know what shape and type of bits i need, and a good online source to get them from.
Eran
2 flute upsprials are a must have. If you plan on doing any 3d then you should get a couple of ball end mills too.
links
https://www.shoprutlandtool.com/catalog/
http://www.eagleamerica.com/
http://www.discount-tools.com/index.htm
http://www.cdcotools.com/index.php
That should get you started![]()
