Old 04-19-2005, 07:15 AM
edbo68 is on a distinguished road
Machining threaded shaft ends.
This is a question For those of you that machined thier own threaded shaft ends down to fit couplings and bearings. I have a Sherline lathe and only had it for a few months. I want to turn down the ends of 3/8"-16 tpi threaded rod. The rod fits through the spindle of the lathe but the rod is 20" long.
How do I prevent the threaded rod from whipping around wildly out of the back of the spindle of the lathe or how did you guys do it I should say?.
Even if I were to support the rod between centers there would be alot of the threaded rod sticking out of the end of the spindle unsupported.
Please shead some light, tip, tricks etc..
Ed
Old 04-19-2005, 07:46 AM
JRoque is on a distinguished road
Hey Ed,
I was in that same spot a couple of months ago. Here's a link on how I did it: http://www.cnczone.com/forums/showth...2&page=4&pp=10
Basically, I used a couple of flange bearings to stiffen up the material while being cut. The bearings I got had set screws which made it an easy fit. If you can't find bearings that match the OD of the material you want to cut, slip a piece of PVC over the material to take up the slack and then fit the set screws. One of the bearings can be mounted on the steady rest and the other, if necessary, held with a bench press as seen in the link above. The screws I cut were 72" long and they were my first job on a 9x19 lathe. I also used this method later on to cut a spindle. The bearings made it possible to make much more precise cuts than otherwise possible with just the chuck holding the material. It also beats using a steady rest any day.
Regards,
JR
Old 04-19-2005, 08:53 AM
JR,
Thanks for the info!!!
I was going to use a steady rest too. The bearing and PVC Idea will make life easyer.
Did you have a lot of trouble setting up the rod to run true from the bearing to the spindle of the lathe?
Ed
Old 04-19-2005, 09:12 AM
Hey Ed,
I didn't have much problem centering the screw on the lathe. I used the live center to locate the screw's center and then mounted the bearing to the steady rest bracket to match that. You might have to cut a small plate to mount the bearing on the steady rest so its centered on your lathe.
With the first screw I cut, I didn't use the bearing and figured the screw was strong enough and sticking out of the chuck short enough that would be rigid for cutting. However, even the 5" sticking out of the chuck would bend a bit and cause problems maintaining good accuracy. This might not be a problem for your application. The second screw was cut using the bearing method and that worked great.
There are tons of sources for the flange bearing and you can probably pick them up locally but if not, here's where I got mine from: http://stores.ebay.com/KML-BEARING-S...eNameZl2QQtZkm
JR
Old 04-21-2005, 11:53 AM
Hobbiest is on a distinguished road
Sounds like way too much spindle speed is being used if excessive shaft whip is present. I am not a machinist, but all of the lathe work that I have done has not given me this problem until higher speeds. The lathe was much larger too, but 200-400 Rpm isn't too fast, will still cut. Just a thought.
Stop talking about it and do it already!!!!!
Old 04-28-2005, 03:01 PM
peter@slater is on a distinguished road
live center
Would a spring loaded live center help in an application like this?
I've been wondering if anyone has tried them in an application like this.
Peter
Old 04-28-2005, 09:44 PM
LeeWay's Avatar
LeeWay is on a distinguished road
My little mini lathe is on a rolling tool cabinet with a wooden riser built on top. I just clamped a small piece of plywood with a hole in it to a work bench. The long shaft was supported very well this way.
Lee
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Machining 2219-t4 aluminum scottwally General Metalwork Discussion 2 06-18-2005 10:53 PM
mounting flexible couplings to 17mm shaft cowanrg General Metalwork Discussion 14 04-11-2005 12:40 AM
Thompson Shaft and bearings flex help? foamcutter DIY-CNC Router Table Machines 9 04-24-2004 04:24 PM
Threaded rod ends and recommendations CNC Brute DIY-CNC Router Table Machines 0 01-15-2004 05:22 PM
