Old 02-20-2010, 08:57 PM
jestah is on a distinguished road
Question Is it safe to underpower my motors for the test bench?
Hi guys,
I have been waiting on my caps to arrive to finish my motor power supply and to test my controller but they are taking forever. I have most of the system mapped out and keen to see if I can get my computer talking to the controller asap.
While I wait for my caps to arrive would it be safe to use a much smaller switchmode 12v/5A supply and use the correct current limiting resistors to test my controller to test my system? Also what current is safe to run into 203v before they need to be heatsinked?
The motors I have are Nema 34 960 oz/in Stepper from homeshopcnc and 4 203v
Jestah
Old 02-20-2010, 10:22 PM
stangtjk is on a distinguished road
I don't think its going to damage the motors any, I'd be more concerned about the drives. I believe the G203v requires at least 15V.
Old 02-20-2010, 10:37 PM
wow, your right it could harm the drives....
Good thing im a horder and have a small collection of junk around and found a 300va 24v toroidal transformer and some 10000uf 75v caps that could work until my 100v caps arrive.
thanks for the heads up before i blew my drives!
Old 02-20-2010, 10:41 PM
"HEATSINKING: The G203V needs heatsinking for current settings greater than 3 amps. The case temperature"
I have just relised that my heatsink has not arrived yet either. would it be safe in the mean time to install a 12.8K resistor and limit the current to 1.5A at around 34v?
Old 02-21-2010, 12:41 AM
arizonavideo's Avatar
arizonavideo is on a distinguished road
Just set the drive on a scrap of aluminum.
They don't get vary hot at 4A.
Question on test/tuning motors ? KEYTEEM Servo Drives 1 04-10-2009 06:27 AM
Diesel Test Bench turbocanuck General Electronics Discussion 5 11-15-2006 02:44 PM
Procedure for bench testing SEM servo motors boringmill Servo Motors and Drives 4 04-11-2006 07:43 PM
how to test servo motors? cowanrg Servo Motors and Drives 5 10-11-2005 04:59 PM
Is this safe? Hack DIY-CNC Router Table Machines 3 07-27-2005 07:00 PM
