Old 02-16-2010, 04:35 AM
sylvester1073 is on a distinguished road
Straightening Acme lead screw?
Hi all,
I have just about finished my first CNC machine and received the Acme screws from the USA today. Both screws (36") have bends in them of about 1/4"- 1/2" over their span. What is the best method i should use to straighten them evenly, and will their accuracy be affected? Or am i just worrying too much?
Thanks kindly in advance,
Julian.
Ps. I will post some photos soon of my machine
Old 02-16-2010, 10:53 AM
ger21's Avatar
If they don't whip, then you don't need to worry about it.
Mine were whipping, so I layed them on a flat surface, and rolled them back and forth to find the bends. Then I carefully bent them by hand. They ended up having more smaller bends, but getting rid of the major bends reduced the whipping considerably.
Old 02-17-2010, 12:19 AM
arizonavideo's Avatar
arizonavideo is on a distinguished road
I had to straighten mine and I had good luck putting them on the mill with two v blocks and an indicator in a drill chuck with the 3/8 shaft going through the indicator mount so I could use it as a press.
I used the quill and the shaft to bend the rod straight after I found the high spots.
I set the v blocks about 6" apart and turned the rod to find the highest spot and then pressed it a bit with the 3/8 shaft in the drill chuck.
I was able to get a 1/2" bend down to about .010
A drill press would also work for this.
They bend easy so be careful.
Acme lead screw 1.5 meter up osix Want To Buy...Need help! 0 04-16-2008 10:57 AM
Acme Lead Screw Questions Eurisko DIY-CNC Router Table Machines 4 03-26-2007 05:19 PM
acme lead screw swarfmacdaddy Linear and Rotary Motion 4 12-11-2005 07:09 AM
Acme Lead Screw Decision js15 DIY-CNC Router Table Machines 0 07-20-2005 02:44 PM
acme lead screw article sdwilson DIY-CNC Router Table Machines 1 12-14-2003 12:33 AM
