Old 02-10-2010, 08:22 PM
Tristar500's Avatar
Tristar500 is on a distinguished road
Heavy large scale gantry mill/router/3d carving 5 axis build
Been working on the design of my latest machine. I've got a half dozen cnc machines under my belt now and with the help of others here on the forum and 2 years designing the build has started on my most ambitious project to date, a 5 axis mill.
I plan to use the machine to help in the fabrication of the sculpture that I create. Specifically
3D carving of the female form.
Here's a couple of examples of my sculptures and the general layout of the machine.
Name:	Picture 458 (Medium).jpg‎
ID:	99761   Click image for larger version
Name:	Picture 460 (Medium).jpg‎
ID:	99762   Click image for larger version
Name:	Picture 464 (Medium).jpg‎
Is a sentance fragment?
Old 02-10-2010, 08:27 PM
Tristar500's Avatar
a few of the sculptures I do and will be able to scale up and down with the new machine.
Name:	Amy.s (Medium).jpg‎
ID:	99765   Click image for larger version
ID:	99766   Click image for larger version
Name:	Picture 061 (Large).jpg‎
Old 02-11-2010, 02:44 PM
awerby is on a distinguished road
Sounds ambitious okay
Did you really carve those sculptures with a CNC mill? They look more like they were welded or soldered together. Do you think the aesthetic qualities they have will survive the scaling-up (or down) process intact?
Do you have a design worked out for the 5-axis mill? It's hard to see what you're planning to do from the miscellaneous pieces of steel and process shots you've shared so far.
Andrew Werby
www.computersculpture.com
Old 02-11-2010, 07:03 PM
Tristar500's Avatar
Today was a huge day for visual progress. The months of fabrication of the parts including the gantry are finally one. It'll take the next day or two to make sure the frame is plumb and the rails are properly aligned.
CNC metal mill drilling pilot holes for the brackets that hold the frame in place.
Brackets welded to cross members and opened up to .75" to receive the bolts that will hold the structure together.
Gantry is introduced to the frame for the first time. Hopefully my CAD skills and measurements are close...
A little while later the gantry is carefully lifted via a floor jack a foot or so of the floor. Step one..
a couple of hours later the gantry is getting closer to home..
Gantry finally in place. This was heavy and dangerous work. Balancing a piece of steel like this on one floor jack and then rotating in 90 degrees is a *****. Resting for a while..
Here's a shot of my now messy shop with me in the pic so you can get a feel for the size of the machine.
More as it happens...
Name:	Picture 457 (Medium).jpg‎
ID:	99820   Click image for larger version
Name:	Picture 460 (Medium) (2).jpg‎
ID:	99821   Click image for larger version
Name:	Picture 461 (Medium).jpg‎
ID:	99822   Click image for larger version
Name:	Picture 473 (Medium).jpg‎
Name:	Picture 474 (Medium).jpg‎
ID:	99824   Click image for larger version
Name:	Picture 479 (Medium).jpg‎
Old 02-11-2010, 07:23 PM
Tristar500's Avatar
Molds were made from a real person, then the pieces that make up the sculpture were welded together.
Sorry for the confusion..
Andrew Werby
Old 02-13-2010, 07:23 PM
Tristar500's Avatar
Today I put a jig together to align the primary THK rail along the X axis. Holes were drilled and then tapped with using lots of cutting oil and the slowest speed on my cordless drill. I set the clutch on my drill near it's lowest setting and got all the holes done without breaking a single tap.
Later the rail was placed on the frame and each socket head cap screw was installed so that they are all still loose but the heads are beneath the surface. This allows me to move the gantry back and forth to get at all the screws.
Late in the day I started positioning the X axis ball screw assembly, more on that in the next few days...
Name:	Picture 472 .jpg‎
ID:	99967   Click image for larger version
Name:	Picture 473 .jpg‎
ID:	99968   Click image for larger version
Name:	Picture 479 .jpg‎
Old 02-20-2010, 08:03 PM
Tristar500's Avatar
Can a man have too many clamps? NO!!
Here I am setting up the ball screw for the X axis.
Once measurements were taken it went to the CNC mill to make the mounting brackets. Everything will be roughly aligned and then shimmed to precision near the build end.
Next step: Contemplating the 5th axis.. Here in place with yet more clamps... Thinking...
Name:	Picture 472 (Large).jpg‎
ID:	100436   Click image for larger version
Name:	Picture 473 (Large).jpg‎
ID:	100437   Click image for larger version
Name:	Picture 485 (Large).jpg‎
ID:	100441   Click image for larger version
Name:	Picture 486 (Large).jpg‎
Name:	Picture 488 (Large).jpg‎
Old 02-20-2010, 11:28 PM
FandZ's Avatar
FandZ is on a distinguished road
You don't F around do you? It's looking great. That 4th/5th axis, depending how you look at it, is going to be all business. How heavy do you think it'll wind up being?
Old 02-20-2010, 11:51 PM
stangtjk is on a distinguished road
I'm more interested in the process of making those sculptures, mostly the part about casting and pulling the molds, how about some detailed pics lol, jk .
Looks like its going to be a nice machine.
Old 03-16-2010, 09:14 PM
Tristar500's Avatar
Been working on the electrical enclosure for the 4 G&L Servo drives. Got luck at the local scrap yard and scored a enclosure box for $5.00 Got all my wiring done in a couple of hours this afternoon.
Next,I took a dell desktop machine and liberated the essentials from the plastic fluff and brackets. Now it will fit nicely in my interface enclosure with it's touch screen monitor.
Name:	Copy (4) of Picture 494 (Large).jpg‎
ID:	103056   Click image for larger version
Name:	Copy (3) of Picture 495 (Large).jpg‎
  #11   Ban this user!
Old 03-16-2010, 09:19 PM
Tristar500's Avatar
Now for the deep Z axis. I hit the local scrap/recycling yard this morning and purchased a couple of pieces of 1 inch thick by 5 inch pieces of 6061 T-6 aluminum. This is the primary material I will use for the Z. I started off by chopping to the length a piece of the material to mount the bearings. A chop saw with a carbide blade made the cut quickly. I'll set up the mill to true the end after rough cutting to length.
Name:	Picture 497 (Medium).jpg‎
ID:	103059   Click image for larger version
Name:	Picture 496 (Medium).jpg‎
  #12   Ban this user!
Old 03-16-2010, 09:32 PM
Tristar500's Avatar
A couple of years ago I picked up a couple of THK linear rails and cassettes at the same scrapyard for $10 for the pair. I got 4 rails and 4 cassettes and some .5 inch aluminum. The rails are about 26 inches long. An hour later I had it stripped down and a "pile o' parts" on the table. Bearings were well greased as you can see and are in excellent shape. Time for some thinking..
Name:	Picture 490 (Medium).jpg‎
ID:	103065   Click image for larger version
Name:	Picture 492 (Medium).jpg‎
ID:	103066   Click image for larger version
Name:	Picture 509 (Medium).jpg‎
ID:	103067   Click image for larger version
Name:	Picture 494 (Medium).jpg‎
Want to build stout gantry CNC router Jr's Farm DIY-CNC Router Table Machines 7 10-23-2009 02:37 PM
3 axis CNC Gantry Mill, or CNC Router Frame, Ballscrews, Linear Rails, Covers, Etc. qualitymachine EBAY ADS 4 06-02-2009 10:02 AM
Very Large Gantry Router Questions IAD Open Source CNC Machine Designs 115 01-19-2008 12:23 PM
heavy gantry drafterman JGRO Router Table Design 6 11-07-2007 10:59 AM
Aussie gantry router build number 4 Rodm1954 CNC Wood Router Project Log 21 08-01-2007 02:43 PM
