Old 02-09-2010, 04:59 PM
GeeksGoneBad is on a distinguished road
pillow block bearings
Hey everybody! I had a quick question... I'm trying to use two brand new pillow block bearings (these to be exact - http://www.thebigbearingstore.com/se...Bearing/Detail)
well I got them in today and also some 5/8" stainless steel shaft... the shaft fits perfectly in the bearings but the pillow blocks aren't flat I think they should be flat - shouldn't they?
if these don't lie flat then how the heck are you supposed to use them? LOL
I'm attaching a picture for reference - but I think I got some bum pillow block bearings (which by the way are both skewed)
Check out my projects at www.backyard-workshop.com
Old 02-09-2010, 05:10 PM
revwarguy's Avatar
revwarguy is on a distinguished road
I think you're right - they're bum ones. I would send them back with your photo and tell them you either want some that are true, or your money back. Of course, you might get someone with a machine mill or surfacer to make them flat, but you really shouldn't have to.
Old 02-09-2010, 06:33 PM
Jesse B's Avatar
Jesse B is on a distinguished road
Those definitely look defective. I'd contact the seller and see what you can do.
Old 02-09-2010, 07:05 PM
BigMike4u is on a distinguished road
Those appear to be self aligning pillow blocks. If they are, the shaft hole will align itself when you bolt it down.
Post a picture of the side of one of the blocks please.
I live in my own world, but that's ok they know me here.
Old 02-09-2010, 07:06 PM
FandZ's Avatar
FandZ is on a distinguished road
I have the 1/2" of those bearings and the bottom of mine are flat. It was a pain to get the swivel inner bearing to unlock so I could get them parallel with each other. I didn't use a grease gun so I probably made the job a lot harder than it needed to be.
Old 02-09-2010, 07:48 PM
Ah - it would be nice if they are self aligning here's two more pics - and thanks for the help
ID:	99680   Click image for larger version
Old 02-09-2010, 07:57 PM
Torsten's Avatar
Torsten is on a distinguished road
Smile
Same as those
http://www.mcmaster.com/#mounted-bearings/=5qzr3f
Read the part about "Extreme Misalignment" in the specs.
That should clear things up, I hope.
Old 02-09-2010, 08:19 PM
FandZ's Avatar
Make sure you loosen the inner bearings up before you try to bolt it all together. I soaked mine in oil, then clamped mine down and used a 1ft socket extension to pry it free. You should be able to get them loose enough that you can adjust the alignment by hand. Once you get them loose you can actually flip the bearing upwards and it'll slide completely out of its housing.
Old 02-09-2010, 08:33 PM
FandZ's Avatar
Geeks, you're not planning to use those bearing as end supports for your rods? I'm just trying to figure out why you have a smooth shaft inserted in the picture.
Old 02-09-2010, 08:52 PM
Yes, they will align. As stated, some oil and a little work and they will move.
  #11   Ban this user!
Old 02-09-2010, 09:05 PM
Cool - thanks for all the advise guys - I will work them out tomorrow
FandZ - my idea for these are going to be the bearings for my new 4th / rotary axis - the one I made before was with MDF and a little on the loose side
Edit: Actually I couldn't wait - just got back from the garage working out the bearings - all's good, sorry for being a n00b hehe
Thanks again guys!
  #12   Ban this user!
Old 02-09-2010, 09:20 PM
FandZ's Avatar
Ahh... Should be real smooth. Looking forward to it.
Seen these on TradeMe - linear bearings with pillow blocks cncmachinemad@g Australia, New Zealand Club house 2 10-22-2009 01:22 AM
Source for open linear bearings/shaft/pillow blocks ? cnczoner Linear and Rotary Motion 17 10-15-2009 12:52 PM
Linear Pillow Block Slide Bearing Specs. How accurate will my cuts be? JimmyL Linear and Rotary Motion 1 06-11-2009 08:51 PM
small bore ball bearings w/ pillow block or flaged Blaise DIY-CNC Router Table Machines 0 05-22-2007 05:48 PM
Twin Pillow Block -- Cut in a Half OK? energyforce Linear and Rotary Motion 4 11-04-2005 06:29 PM
