Hello I'm finally getting to the end of building my cnc router after about a year, I'm building my control center now and need some help on relays, I bought some Crydom EZ240D18 relays from MPJA I have never used solid-state relays before, the input side is 5-15vdc and output is 120vac 18a I was going to use them to turn on my router with the Gecko G540 when I applied 12vdc to the input side it did turn on the 120vac side but when I removed power to the input the 120vac stayed on I had to manually disconnect the 120vac to get the relay to cycle back to normally off potion am I doing something wrong or do I need some deferent relays, please help |
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| CNC Man, I have exactly that relay hooked up to my G540 controlled by Mach 3. I didn't need a bleed resistor, I think that the G540 will provide that. In any event, my router turns on and off on command without fail. More on it at www.liming.org/cnc |
| Need Help!- Gecko G540 Relay Help | The CNC Man | Stepper Motors and Drives | 2 | 12-03-2009 04:11 PM |
| do you know if the g540 uses the gecko setting? | draughted | LinuxCNC (formerly EMC2) | 15 | 10-06-2009 01:37 AM |
| Need Help!- Question Gecko G540 | rotger | General Electronics Discussion | 0 | 06-02-2009 03:59 PM |
| Need Help!- Gecko G540 | rotger | Servo Motors and Drives | 0 | 06-02-2009 12:43 PM |
| gecko g540 | Teyber12 | Benchtop Machines | 3 | 05-31-2009 02:23 PM |
