Old 01-30-2010, 05:21 PM
Drools's Avatar
Drools is on a distinguished road
Will these work?
I'm using 2 of the THK SHS15V linear bearings 1 per rail for my Z axis. I'm using a simple light weight spindle but I'm working on making a mount for my Porter Cable 9690LR router. Will the SHS15V linear bearings be ok for use with the PC router? I have 2 more bearing blocks that I could add to the Z-axis if needed. How do I read this information?
https://tech.thk.com/en/products/thk...th.php?id=1103
How much force is 1kN in compariable terms?
Old 01-30-2010, 10:12 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
1KN = 220lbs (or so)
Keep in mind that I think kN is a unit of force so my direct conversion to weight is probably wrong....
Old 01-30-2010, 10:16 PM
mlabruyere's Avatar
1Kn = .1Kg = .22lbs
Or something like that.....
Old 01-30-2010, 10:33 PM
ger21's Avatar
224 lbs
Old 01-30-2010, 10:38 PM
Drools's Avatar
hmmm I'm still not sure if I should add the extra bearings to the axis or not.
The PC router weight 8lb Net. I found this site http://www.convertworld.com/en/mass/Kilonewton.html
I converts 1 kN to 273lb. The Dynamic rating for radial is 14.2kN and Static is 24.2kN but I'm not sure what the numbers mean.
Old 01-30-2010, 10:40 PM
ger21's Avatar
It means as long as your Z axis is less than 3000 lbs, you should be OK.
Old 01-30-2010, 10:42 PM
Drools's Avatar
would I also have to make sure the cutting forces are less than 3000lbs?
Old 01-30-2010, 10:56 PM
ger21's Avatar
yes.
Old 01-30-2010, 11:06 PM
Drools's Avatar
Is there a chart of typical cutting forces for hardwood?
I guess the bit, doc, feed rate and a whole bunch of factors would contribute to calculating the "Cutting Force"
Do you think I will be exceeding the 3000lb rating if I were doing wood and plastic with the Porter Cable?
Thanks for the help!
Old 01-30-2010, 11:17 PM
ger21's Avatar
You won't exceed 50 lbs. Those bearings can support far more than you'll ever need.
  #11   Ban this user!
Old 01-31-2010, 04:02 AM
mlabruyere's Avatar
Your bits will break well before you get anywhere close to that kind of force...........but you know your bearings can take it......
  #12   Ban this user!
Old 01-31-2010, 01:05 PM
Drools's Avatar
Well I have broken a few bits already.
I found an interesting article on the SHS bearings.
http://www.fignoggle.com/components/...comparison.htm
Need work denmar Employment Opportunity 0 07-10-2009 11:03 AM
Looking For A Job- how work usa rtm74 Employment Opportunity 3 05-27-2008 03:30 AM
Newbie- Work Planes / Work Coordinates MICFDI Esprit 9 05-11-2008 11:35 PM
Looking for someone in LA for CNC work originator Employment Opportunity 1 04-10-2008 08:10 AM
How does a DRO work dberndt General Electronics Discussion 4 12-31-2004 09:24 AM
